PostgreSQL database location?
notiusweb
Looking for some help regarding location of PostgreSQL database in relation to old Valentina database.
In 4.8 when exporting user data, just runs (as in hourglass) but never appears to count from 1% upwards to 100% like Valentina did. Following the "export", the user data in ...support/user data (location of old Valentina database) remains untouched. When asked to import, it selects from the same location as the old Valentina. Almost seems as if you can no longer export a new post PostgreSQL database
This Q&A guide:
https://helpdaz.zendesk.com/entries/45231914-PostgreSQL-FAQ
makes reference to a separate PostgreSQL database in the 2nd to last question
"Q: What happens to Valentina CMS when I install PostgreSQL CMS?
A: Valentina CMS will not be uninstalled and its database will be left untouched. This won't cause problems -- if PostgreSQL CMS is installed, DIM and DS will use it even if Valentina CMS is also running at the same time. Therefore any new content you install or new user data you create will be added to the PostgreSQL database and not to the Valentina database. If you wish to uninstall Valentina CMS you may do so, but it is not required."
So, where is this new PostgreSQL database typically stored? THANKS!
you can see current CMS and database location , in daz studio
top menu>edit>prefference>CMS setting tab,(F2 key)
as for me, it is C:/Users/my user name /AppData/Roaming/DAZ 3D/Cms
but exported user data have not changed location, from valentina and postgre.
content root directory(My library etc) /Runtime/Support/UserData_1.dsx
did you check log file, when you try export user data?
I think there was some erroer message.
when I export user data, log discribe it.
You are right, I am getting an error message. I am going to open a new topic regarding that. But thanks for the information on the location!
