Shaders seem to not find difuse
Bought several of the shaders in the recent sale. Downloaded them with Install Manager all to default places
When I pull in a primitive and apply one of the shaders it just appears white in a render.
Some shaders are working fine but some sets I just cant see how to make work...
Historical Masonery 2
Historical flooring for Daz4
Dark Corrosion
Dirt Shaders
Need to check others
Anyone know how to fix?
Thanks in advance
  • Richard HaseltineRichard Haseltine Posts: 111,769
    Are you selecting both the item and the surface on the item you wish to affect? Are you using 3Delight or Iray?
  • edited December 1969
    I was using iray and selecting the item. Some shaders that I purchased worked. The ones above seemed to be applying a partial shader but seemed to not be finding the difuse.
    They are, I think, all Shader Mixer shaders - it may be that the properties are not named in a way that allows the conversion to Iray to pick them up. You will probably need to apply the shader to a primitive of some kind so you can use it as a guide to set the maps and values in the Iray Uber shader, and please report the issue to Tech Support so an update can be made if it's needed and possible.
