Daz Smoothing not working
I am getting this weird problem. It started after i upadted to lates version i think. Whenever i apply smmothing modifier it works inthe viewport but in final render it doesnt. which is weird.
Bec of this i have to use push modifier to fix the pokethrough.
Anyway knows problem and the fix for it??
  • Richard HaseltineRichard Haseltine Posts: 111,389
    Is this in saved scenes or does it happen in new scenes too/only?
  • hansolocambohansolocambo Posts: 649
    edited June 2022
    Check the Resolution Level of your Genesis and its clothes eventually (Parameters > Mesh Resolution).
    If your View SubD Level is higher than the Render SubD Level, it could explain the difference you see between the precision of the smoothing effect between viewport and render.
    Post edited by hansolocambo on
