Pose Genesis + accessoires
FuerchanFuerchan Posts: 63
Hello,
I give the position in Genesis with a weapon. Then I save in "Preset Pose". But when I give the pose a new Genesis, Genesis takes the pose correctly. But the weapon is not following the movement correctly.
How to save the pose for Gensis and its accessory?
Thank you ;-)
F.
    The simplest way would be to save the Figure and the Prop as a Scene Subset, you can also save the clothes and hair too if necessary. You can then merge that Scene Subset into any future scenes.
  • Richard HaseltineRichard Haseltine Posts: 112,078
    A Hierarchical Pose Preset will pose both the figure and parented items. The item does need to be parented, though, which by the description may not be the case here.
