Newbie question: Transfer Utility issue
PA_ThePhilosopherPA_ThePhilosopher Posts: 1,039
Hey guys,
So I have a static hair object that I imported and ran the transfer utility on. But for some reason, as soon as the transfer utility completes its calculations, the hair object moves away from the head to another location. The utility seems to have worked, b/c when I move the character, the floating hair also moves. But my problem is it did not remain in place on his head.
Do you guys have any idea what the issue may be?
-Davide
  • Tramp GraphicsTramp Graphics Posts: 2,435
    When you imported it, did you move it to try and fit it to your character? If so, that's your first problem.
  • Richard HaseltineRichard Haseltine Posts: 112,087
    If you did move it to line up with the zeroed figure, try hiding everything, then export as OBJ and reimport using the same preset, reapply materials, and use the Transfer Utility on that version.
    Yes, lining it up, exporting and reimporting (Richard's method) is the easiest way to handle it.
  • PA_ThePhilosopherPA_ThePhilosopher Posts: 1,039
    edited June 2015
    Ok thanks guys. That did it. I didn't realize the character not only had to be reset in its pose, but also zeroed in its coordinates as well.
    Thanks again,
    Davide
    Post edited by PA_ThePhilosopher on
