My UI is broken...
The latest update (which I just installed) completely broke my UI.
http://i60.tinypic.com/214p0f6.png
How do I fix this? There's no styles in the Window menu and a UI reset from Edit -> Preferences did nothing.
Thank you!
Edit: It's not broken.. it actually works just fine. It's just flat white with black text with no other visible UI elements, including sliders and tabs and such. If I click on them they still work, they're just invisible.
Windows 8.1, in case that matters.
Post edited by christopher-2607496 on
I have only ever seen this happen when DAZ Studio has been open when the update took place.
You will need to uninstall and re-install again. The content is not affected, only the program.
That worked. Thank you!
Thanks, that worked for me as well.:cheese:
