Are Ghost Lights incompatible with Gobo lights?
EZ3DTVEZ3DTV Posts: 1,688
Are ghost lights incompatible with gobo lights?
I have "Light 2 Life Light Gels for Iray" lights and I added a square ghost light from "Iray Ghost Light Kit" and my Light 2 Life gobo lights went out.
Is there some kind of incompatibility issue here?
I am using Daz 4.20
Thanks in advance for any responses.
Post edited by EZ3DTV on
  • Richard HaseltineRichard Haseltine Posts: 111,852
    Well, they might well wash the lights out - and if the gobos are shinging through a screen then a ghost light, with its large area of emission, would blur the shadows if used as the source light.
  • EZ3DTVEZ3DTV Posts: 1,688
    Hello Richard, thank you very much for your comment.
    I did not substitute the gobo light source for the ghost light,
    I just added the ghost light to the scene and the gobo light sources turned themselves off.
    I will test it out more extensively.
    It could be an error on my part somehow.
  • FirstBastionFirstBastion Posts: 8,085
    As Richard said it could be an intensity issue, if  the ghost light is bright enough to obscure the shadows generated by the gobo. Check the illumination numbers for each and see if there is a large variation in numbers between the gobo and ghost lights.
