Will a DS4.7 file render the same in DS4.8 if using 3Delight setting?
WillowRavenWillowRaven Posts: 3,787
I have to edit an old cover scene and don't want the over-all look of the render to change since the only thing I have to change is the character's expression and hair color.
  • scorpioscorpio Posts: 8,533
    Should render the same possibly a bit quicker.
    Yes, there is a bit of speed improvement between the 3Delight versions. But other than that there were a couple of other fixes/improvements in 3Delight...which actually increase the overall quality of the render. Especially if you turn on Progressive mode for your 3Delight renders.
  • ScavengerScavenger Posts: 2,677
    What is "progressive mode"?
    It is a render method that makes several 'passes' through the scene to get to the final image. A lot like the iterations in Iray. But what it does, with 3Delight, is enable the faster raytrace part of 3Delight.
  • acanthisacanthis Posts: 604
    Although I was VERY skeptical about installing 4.8 I have found no problems rendering existing scenes. I don't see any reduction in quality - possibly an ultra-miniscule improvement in some scenes. As for the much talked about speed-up of 3Delight, I never experienced this, or if it was there it was in the sub-picosecond domain. Better to just switch to iRay, which IS faster for me.
  • WillowRavenWillowRaven Posts: 3,787
    Ugh! Installing 4.8 totally screwed up my system.
    I am left with no other option but to refresh windows and start over, and this is a new computer (Alienware) with a nvidia card, so I know capabilities isn't the issue.
    Somehow, it reset my virtual memory settings to none and refuses to revert back to original settings.
    Hopefully the refresh will resolve it and I can avoid a total restore.
    I shouldn't have tried to upgrade.
  • frank0314frank0314 Posts: 14,945
    What did it do to screw up your system?
  • algovincianalgovincian Posts: 2,687
    Not saying this will be the case for every scene, but here is some hard data on the speed increase for one of my scenes:
    http://www.daz3d.com/forums/discussion/56967/#829418
    Huge improvement!
    - Greg
    All I did was install 4.8 ... then suddenly I have no virtual memory.
  • Richard HaseltineRichard Haseltine Posts: 110,703
    Neither DIM nor DS touch those settings. Very few things will, as far as I know.
    I wouldn't have thought so, but I only did that one thing, and within an hour ... chaos.
    Three things off the top of my head that can: Windows updates, malware and some 'system utilities'...
