Hair clipping / skull cap edge showing in renders. What to do?
CHWTCHWT Posts: 1,191
This is especially bad with the Tjark Hair, which is a bummer because other than the hair clipping / skull cap edge showing in renders, it's perfect! Anyone has tips to deal with this?
  • lou_harperlou_harper Posts: 1,163
    Do you mean the black marks that show on the forehead? If so, you need to upscale the skullcap a little.
  • FauvistFauvist Posts: 2,290
    what happens  if you make the skull cap invisible?  Or reducing the scale of the portion of the skull cap that's showing - like the Z axis scale.  Or check the "fit to" setting to make sure it's fit to the correct figure? Or moving the skull cap backwards slightly?
  • HavosHavos Posts: 5,703
    If you are using Iray this is a well known issue that affects many hairs that use partially transparent skull caps. There have been a number of threads raised about the issue which is caused by rounding issues in the renderer. Here is a thread that tells you how to fix:
    https://www.daz3d.com/forums/discussion/537851/fixing-black-forehead-lines-black-eyes-and-red-skin-correctly
  • CHWTCHWT Posts: 1,191
    Yes. Will try, thank you!
    I will check if I can make the skull cap invisible, thank you!
    Oh yes, I forgot I read somewhere about the instancing tip. Will try this first, thanks!
    Really appreciate all of your help!
