Problem with Transfer Utility...
Hi,
I use Transfert Utility for the meshes that I import in DazStudio.
For the dresses, I use dForce or Marvelous if I have a large number of frames.
Until now, I had only imported short hair, and Transfer Utility gave satisfactory results.
But when I used Transfer Utility for long hair (with option Shoulder Length Hair) I got an imperfect result.
For some poses, the hair goes into the body of character (as we can see in the picture below)
I consulted the online help for Transfer Utility. I tried to use Convert to a SubDivision Surface, but the result is the same.
Of course, I can find a way to get the bottom of the hairstyle away from the chest by creating a morph.
However, I would like to solve this problem with the DazStudio tools.
  • LeanaLeana Posts: 13,670
    Transfer utility will give you a starting point for rigging, but that doesn't mean it will work perfectly in all situations.
    You might need to alter the weight maps manually to get better results or maybe create custom posing bones or morphs. That's especially true for hair.
