Upgrade to RTX 3080 : can I keep my current configuration?
Hello All,
My sister is keen to give me her GC as she changed her job, it's a RTX  3080 TI, to replace my 2060
Can you confirm I can install it with my current system or , in case I should change something, what should I change , I have a very limited $300 budget if necessary,
Thanks a lot  !
K
Operating System
Windows 11 Professional ‎(X64)‎ 21H2
System install date: 2/6/2022
Processor
AMD Ryzen 5 3600 clocked at 3.75 GHz
Processor frequency measure (core0): 3.75 GHzNumber of cores: 6 physical, 12 logicalProcessor socket: Socket AM4 (1331)CPU Temperature (core 0): 95.25 °C
Motherboard
Micro-Star International Co., Ltd. MPG X570 GAMING EDGE WIFI (MS-7C37) 1.0
SKU Number: To be filled by O.E.M.Bios version: 1.G0Date: 12/16/2021
Chipset
Northbridge : AMD Ryzen SOC
Revision ID: 00
Southbridge : AMD X570
Revision ID: 51
Memory
16 GB total memory type DDR4 to 2.66 GHz (1.33x2 GHz)
Memory timing: 16.0 clocks-18 clocks-18 clocks-35 clocks-1 TT
Memory chip Corsair of 8 GB
Maximum frequency: 1066 MHzMax bandwidth: DDR4-2133Maximum frequency XMP: 1333 MHzMax bandwidth XMP: DDR4-2666
Graphics card
NVIDIA GeForce RTX 2060
DirectX version installed: 12.0Core clock: 1.89 GHzMemory clock: 6.80 GHz
Harddrive
Harddrive ST2000DM008-2FR102 of 1.82 TB SATA III
Firmware: 0001SATA version: SATA Rev 2.6
SSD Samsung SSD 980 PRO 2TB
Firmware: 3B2QGXA7
SSD Samsung SSD 970 EVO 1TB
Firmware: 2B2QEXE7
Network
Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
Adapter type: ethernet
TAP-NordVPN Windows Adapter V9
Microsoft Wi-Fi Direct Virtual Adapter
Adapter type: IEEE 802.11 wireless
Microsoft Wi-Fi Direct Virtual Adapter #2
Intel Corporation Dual Band Wireless-AC 3168NGW [Stone Peak]
Bluetooth Device (Personal Area Network)
Software Loopback Interface 1
Adapter type: Loopback
Multimedia cards
NVIDIA Corporation TU104 HD Audio Controller
Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
Keyboard
HID Keyboard Device
HID Keyboard Device
Mouse
HID-compliant mouse
Screen(s)
C24F390
Manufacturer: SamsungMaximum resolution: 1920 x 1080Screen size: 23.4" (52 cm x 29 cm)Manufacture date: 12/16/2019Aspect ratio: 16:9Video input type: Digital Signal
USB peripheral
Micro Star International USB Input Device
Genesys Logic, Inc. Hub (Generic USB Hub)
Intel Corp. Wireless-AC 3168 Bluetooth (Intel(R) Wireless Bluetooth(R))
  • barbultbarbult Posts: 27,497
    Check the new card dimensions to be sure your system has physical room for it.Some graphics cards are large, both in length and number of PCIe slots required.
  • nakamuram002nakamuram002 Posts: 823
    Check your power supply's capacity.  If it is over 700W, you should be OK.
  • Richard HaseltineRichard Haseltine Posts: 111,363
    What is the current power supply in the PC?
  • PP Posts: 36
    Thanks,
    I have a 600 W Power supply.
    https://www.bequiet.com/en/powersupply/1279
    SYSTEM POWER 9
    600W
    Proven Reliability and Good Efficiency
    be quiet! System Power 9 600W offers renowned be quiet! reliability and quietness for price-conscious PC builders.
    • Rock-solid stability with 2 strong 12V-rails
    • DC-to-DC technology for tight voltage regulation
    • 4 PCIe connectors for powerful GPUs
    • Temperature-controlled 120mm fan reduces system noise
    • Stand-by drain of less than 0.15 watts
    • 80 PLUS® Bronze efficiency (up to 89%)
    • Attractive black sleeved cables
    • Complete suite of top safety features
    • Meets latest Intel® C6/C7, ErP and Energy Star 6.1 guidelines
    • 3-year manufacturer’s warranty
    • Product conception, design and quality control in Germany
  • PP Posts: 36
    Yes, good point !
  • PP Posts: 36
    600W, if it's not enough I can buy a bigger one. I was more concerned about the CPU etc
  • PP Posts: 36
    Thanks
  • GordigGordig Posts: 10,799
    My intuition is that, if your computer can run Windows 11, it can run a 3080ti. As others have pointed out, you'll want a more powerful PSU, and I'd definitely recommend more RAM, aside from the size and space constraints. You might want to consider running the 2060 in addition to the 3080ti.
  • PP Posts: 36
    I will get a 850W PSU so I have some room for future improvement. I thouth my RAM would be enough though. On running both cards do you think it will help ? I'm rendering on 1500*1200 but wiht 3 to 5 characters. The aim with the 3080 is to  get renders done faster, I have a figure in mind but it might be wrong : I'm hoping my renders can be 2x faster.
    edited June 2022
    If a given scene will fit onto your 2060, then it can be rendered on both the 2060 and 3080ti, meaning that it will be even faster than the 3080ti on its own. If it doesn't fit onto the 2060, then only the 3080ti will be used. In either case, you can keep the 2060 driving your monitor(s), freeing up some VRAM on your 3080ti.
    Also, 16GB of RAM is basically the bare minimum to run a computer these days. Renders don't take place entirely on your GPU(s); they require system memory as well, and bigger scenes don't only require more VRAM, but more RAM as well.
    Post edited by Gordig on
    How is your case and cooling, P?  The RTX 3080 TI can get pretty hot.
  • PP Posts: 36
    edited June 2022
    That sounds interesting but two GC might require much more fans I suppose. And what about the space : I will have to understand how connect two CG as I have no clue on this :-).
    It's a RTX 3080, not a TI, does it change something on heat ? I  hope it des.
    For the RAM you're teaching something to me as I 'd never thought that RAM was involved except for saving. So I'll get another 16GB too, but I need to understand where I'll plug them as all the slots are taken - from memory-.
    Thanks for the tips!
    Post edited by P on
  • PP Posts: 36
    The cooling is OK now but indeed it will be a concern.
    In fact step by step I'm piling spending while I thought I should be fine :-)
    1- I need to upgrade my PSU to 700W minimum (150€)
    2-  I need to buy more RAM say 16GB (70€)
    3-  Fans ?
    But these advices are excactly what I need, I prefer to get it righ and spend a bit that getting all burned.
    Cheers
    P
    If your RAM slots are full, you can't "add" another 16GB. You would have to remove the 16 you have and buy 32 (or more). Check your motherboard specs to see how much it can handle. RAM comes in pairs. Your 16 GB would be 2 8s or 4 4s. Check what you really have installed now.
