Making static wheels look like they are spinning for animation
The wheels do not move on this or on a car for example is there any way to make the effect during animation that they are spinning as the vehicle moves forward?
thanks
1803 x 1612 - 4M
  • Richard HaseltineRichard Haseltine Posts: 111,371
    You could add a plane with a motion-blurred image of the spokes as an opacity map.
  • VicSVicS Posts: 1,273
    Interesing,
    and rotate that plane to simulate a spinning motion, how would you determine how much to rotate it if that is the method , can someone give me any starting point, that may take a while t ofigure out if only renderd series wil lshow the wheel spinning I can see how it will work on a car
    where there is no obstruction in front of wheel but on a bike
    how will the image be in back of the wheel supports outside of the spokes?
  • TogireTogire Posts: 457
    You can use a dformer with a wieightmap on the wheels in order to rotate them.
    That will be good, can you explain or share a link or YouTube that can explain the deformed with weight map. Thank you
    You can look at this thread that explains the different steps.
    https://www.daz3d.com/forums/discussion/comment/5646111/#Comment_5646111
    Basic idea is to select the object, add a d-former, select it, in the parmeters>influence choose "weight map", and paint it with the "node weight map brush" tool. Paint red one wheel and put all the rest at 0. After that, you will prbably need to move the dformer base so that it is at the center of the wheel and apply a rotation.
    I never did it for a wheel, but I used this method many times to make a door or a cupboard openable.
    wow great, thanks alainmerigot, was very time consuming to do a door or cupboard?
    No. The geometry of a door is simple and weightmapping is easy. Maybe 15-20mn. (and I am not a champ).
    It should be longer with a wheel, because you must paint the wires, the tires, etc.
  • IvyIvy Posts: 7,165
    yup thats the best solution for daz indeed I use this trick for airplane propellers with great results
    I used a pane in this animation for the planes prop motions  https://www.youtube.com/watch?v=BHtNLJTPZc4
    for wheels though I just add/parent a wheel prop to the bike or car and rotate it as needed
    sounds good thank you evryone
