Torment 8.1 gender-swap
MoogooMoogoo Posts: 136
I am able to swap textures to female for Torment but his tail morphs do not work when loaded onto a female, is there any workaround for this??
Thanks
  • lou_harperlou_harper Posts: 1,163
    edited June 2022
    Instead swapping skins you could turn Torment into female using https://www.daz3d.com/genesis-8-cross-figure-resource-kit
    500 x 1000 - 44K
    Post edited by lou_harper on
  • MoogooMoogoo Posts: 136
    nice idea thanks and nice torment
    How would you do that - doesn't the Cross-Figure Resource Kit only work to transfer clothing from male to female and vice versa?
    Nope. You're thinking of a different product. This one, once installed, is a dial in the Parameters tab.
    1576 x 1360 - 408K
  • tsroemitsroemi Posts: 3,666
    Oh cool, I have the product and never even knew it did that! Thanks!
    I used just UV swap in the end with a tail not attached to the charachter as the other product was nt on sale.
  • sunnyjeisunnyjei Posts: 502
    That's more useful than I realized. I can't believe that isn't the first image in the promo because I just assumed it was going to be a convulted lenghty script and always passed. Definitely not passing now- thank you!
    edited June 2022
    Nope, I have the product you linked, and all it does is convert clothing from male to female and vice versa. You can dial in the male to female clone and vice versa, but that's just the base male or female shape...it won't allow you to see the male morphs on a female character. Unless you're talking about loading Torment as a G8.1M and then dialing in the female clone...I wasn't aware that would work...but even then, it wouldn't allow you to see actual female morphs as options to use (i.e. dialing in Victoria 8.l on a loaded Torment 8.1).
    Post edited by MelissaGT on
