how to zero genesis figure without zeroing the face morphs
thanks for the help
  • Richard HaseltineRichard Haseltine Posts: 112,089
    Zero shape or pose or both? For pose, if the expression was set from the figure, you could just select the visible skeletal bones and zero those (Zero>Zero Eelement(s)), as long as you hadn't used any pose cotnrols on the body. Shape could simply be Edit>Figure>Zero>Zero Figure Shape. If you want to zero pose or everything and some of what you want to zero is on the same node as the expressions then there is no automatic route.
  • VicSVicS Posts: 1,273
    it is just for zero pose, the shape would be the new face so that needs not to be zeroed, oik thanks Ill check it out
