Is there a way to lock polys so D-Forms don't affect them?
ModernWizardModernWizard Posts: 904
Is there a way to lock polys [particularly teeth, tongue, inner mouth] so that D-Formers DO NOT apply to them?
--MW
    edited June 2015
    Yes you can apply D-former weight map to adjust influence.
    to use it,after apply D-former for mesh, (obj or figure root)
    select D-former field, then in parameters tab > influence change mode to "weight map"
    then go to tool settings tab, change active tool > node weight map brush.
    and apply from Unused maps menu, "influences weight"
    it make weight map for d-former on parented nodes (porp or figure) as same as "default sphere efefct" first.
    then if you need , you can delete weight , by select all >fill color zero, or allternate weight etc.
    the only problem for me,, the weight map mode often stop,, for me.
    when I rotate view etc,,,
    (weight map brush tool change to normal icon, and not work any more,,so you may better save many times^^;
    or your work has gone,,)
    988 x 774 - 140K
    1218 x 709 - 170K
    1299 x 772 - 184K
    Post edited by kitakoredaz on
    hten if you hope to Lock poligons,
    you can check respect selection.
    it only work about selected vertices. in node weight map bruh.
    or select by surface group, use poligon selection mode,
    (rasso or bounding box selection, select by surface group as you like)
    then hide poligons or Lock poligons. and return to weight map mode.
    1091 x 837 - 182K
  • HeraHera Posts: 1,962
    That sounds like fun! Definitely something I have to try!
