can 4.8 render transparent backgrounds?
jakzun_9ecf4a7248jakzun_9ecf4a7248 Posts: 25
if so, how?
thank you
  • cdemeritcdemerit Posts: 505
    jaypowers said:
    if so, how?
    thank you
    Yes, yes it can. If using 3delight, it's the same as before.
    If you are using Iray, go to (render setting -> Environment-> Draw Dome->off, Draw Ground -> off) Default is on.
  • StratDragonStratDragon Posts: 3,291
    jaypowers said:
    if so, how?
    thank you
    transparency depends on the file type you save in.
    If you render an image without a background in order for the file to retain the transparency in background use either TIFF or PNG as your target saved file.
