white dots in render
KeithH
I searched and see many have had this issues however, non of their solutions seem to work for me.
Everything is IRAY. The models and clothes worked in other scenes perfect. Took away the room and put her on an open plane and now I get this.
Thanks
1200 x 935 - 1M
1859 x 774 - 743K
Go the the "Rendering" tab ... click on "Filtering" .... Make sure "Firefly Filter Enable" is set to "On" .. and then push "Noise Degrain Filtering" up to 1 (higher if you need to)
Sorry for the late response. I am just now coming back to this. This seems to work. I had to unhide some settings to make this appear. Did not realize there is so much hidden int he menus. Thanks
I had the same problem, but thanks to you guys it is solved. Thanks!
