Not seeing many of the default Iray shaders..where are they?
Eva1Eva1 Posts: 1,249
edited June 2015 in Daz Studio Discussion
EDIT - Nevermind, found them:)
Post edited by Eva1 on
  • DarthDDarthD Posts: 259
    Where did you find them? I cant find any. I'm watching the Dreamlight tutorial and I don't have the Iray folder under shaders.
    "Default Lights and Shaders for DAZ Studio" was updated with Iray content, if you don't use DIM they are in your Product Library here:
    https://www.daz3d.com/downloader/customer/files#prod_13176
    DIM shows they are installed. The Dreamlight tutorial shows an IRAY folder under glass
    517 x 901 - 149K
    DIM Shows lights are installed.
    1920 x 1080 - 133K
    No photometric lights either.
    222 x 424 - 30K
    I have them categorized in Default > Shaders > Iray > Glass, rather than Glass > Iray
    The Photometric lights have now been combined with the standard lights -- the parameters available for the light depend on which render engine is active.
  • namffuaknamffuak Posts: 4,514
    The distant and point lights have photometric properties when Iray is the selected render engine.
    I think I figured it out. I have my content going to another drive and DIM installed the lights on the C drive. I found some other items installed there also so I'm going to make sure everything is on the correct drive.
    That was it. Thanks everyone for helping :)
  • Eva1Eva1 Posts: 1,249
    In my set up I still have a folder in the content library for Iray Beta (can't find and delete it in My Library, or the install folder on my computer) and I was looking at the shaders there - but with the new release build they have been moved to the Iray folder under Shader Presets, so I found them all there. I still don't see Iray listed in the Presets unde the Surfaces tab though...but I never look at shaders there anyway.
