Going to the Chapel - Wedding Bouquet for V4 and G2F - No longer available
DollyGirlDollyGirl Posts: 2,723
edited June 2015 in Freebies
The package contains a wedding bouquet for V4 and G2F. For the DAZ Studio 4.7 version, there is a standing pose and Right hand pose for each of the girls. There are pose files to position the bouquet in both the standing and T-pose positions to make parenting the bouquet easier. I have provided pose mats for "The Poseable Ribbon" by Allan McCormick to add ribbons to the bottom of the handle. I have also created a moire texture for the ribbon. For the Poser and DAZ Studio 3 versions there is the wedding bouquet with a standing pose for V4 and figure poses for the ribbons with the moire texture applied. The wedding bouquet can take shader or material presets. If you do not have any shaders or material presets then in the section below called Free Shaders and Material sets you will find links to some of the packages I used in the promo pictures. I have also included the obj and mtl files for importing into other programs.
You can get it No longer available
The ribbons on the bouquet are Allan McCormick's The Poseable Ribbon" you can find it here.
Post edited by DollyGirl on
  • SixDsSixDs Posts: 2,384
    Wow, Dollygirl. None of my virtual girls are planning on getting married anytime soon, at least not that I'm aware of. But if they ever do, this is the bouquet they are going to get. It's beautiful! Of course, as the "father" of the "brides", I'm always watching costs, so free is good. :)
  • DollyGirlDollyGirl Posts: 2,723
    edited June 2015
    You are most welcome and thank you, SixDs. But you do know that virtual girls can be bridesmaids as well.
    I forgot to add that the dress on Vicky is the My Princess dress here at DAZ. The lovely textures on the dress were made by RedeyeCat. You can get them [here. Vicky's veil is RuntimeDNA's Desert Rose Veil which is free and you can get it here. RedeyeCat provided the transmap and you can get that here. The flowers on Vicky's veil are from this freebie. Her necklace is this one. And Vicky's hair is the Snood by Fisty here at DAZ.
    Yes brides can be very expensive but I hope that RedeyeCat and myself have eased the pocket book just a little bit.
    Thanks for all the info Dollygirl. While we're on the subject, what background set is that alcove, if you don't mind my asking? I'm particularly intrigued by the red marble texture used in it, since I've found that to be a rare commodity.
    No don't mind at all. I usually keep a list of what I used for a published image anyway. I used Palladio - Roman Props & Scene by GrayCloudDesign and Rpublishing over at Rendo. The mountains are Flipmode's Top of the World from DAZ. Rendered with 3Delight, this is a gamma corrected image as well so that will change the colors too. Lights are UberEnvironment2, one distant and one spot light to fill in the alcove. Gamma correction does not require much of a lighting system if you are going for the traditional Sol look. This is where I learned about linear work flow, good stuff: http://www.daz3d.com/forums/discussion/54913/
  • BlazeMystEraBlazeMystEra Posts: 466
    Thank you for this lovely bouquet!
  • barbultbarbult Posts: 27,638
    Already No Longer Available??? I already downloaded it, but is there a reason it should not be used? Copyright issues or something?
