Genesis 2 Female Duplicate Formulas, Genesis Generation X2
OrionPax09OrionPax09 Posts: 419
I recently purchased a copy of Genesis Generation X2 so I could apply the morphs I've been using on Genesis to my G2 models, and thus far, it has worked swimmingly for the most part. Using this plugin, transferring morphs has proven to be the proverbial piece of cake.
However, there is a problem. After the first time I used Genesis Generation X2, the error message "DUPLICATE FORMULAS FOUND
Duplicate formulas found in files. Make sure the Content is properly installed. See the log file for more details" has been showing up every time I load Genesis 2 Female. And I have no idea how to correct the issue.
Also, I have accidentally transferred a couple characters that I did not intend to to Genesis 2 Female. Is there any way of removing the unwanted morphs?
    Hi about gen X 2 duplicate forumula,
    how your log file written? because most of case, it tell you which file and location you need to check.
    Then the gen2 morph files transfered from genesis,
    by gen X are in library(your daz content root )/data/DAZ 3D/Genesis2/Female(Male)/Morphs/D3D Gen X/Genesis/
    you can manually delete each.dsf and icon, if you do not need.
  • OrionPax09OrionPax09 Posts: 419
    First, thanks for the pointers on how to delete the unwatned Gen X morphs.
    As for the duplicate formulas issue, I looked over the log, and...I can't make any sense of it whatsoever.
    Can I copy the log here so someone can look at it?
  • fixmypcmikefixmypcmike Posts: 19,733
    Sure, just copy the lines near the bottom of the log with the Duplicate Formulas error. It's probably a matter of some of the transferred morphs having the same name as other morphs.
    Alright, then. Here are the last few lines from the log. Hopefully, that will be enough to show what the heck is going wrong.
    File loaded in 0 min 8.9 sec.
    Loaded file: Genesis 2 Base Female.duf
    Ran tdlmake on image C:/Users/Owner/Documents/DAZ 3D/Studio/My Library/Runtime/textures/DAZ/Characters/Genesis2/BaseFemale/V5BreeLimbsSS.jpg
    edited June 2015
    Hi, the log is about the file it show error message?
    “DUPLICATE FORMULAS FOUND
    Duplicate formulas found in files. Make sure the Content is properly installed. See the log file for more details”
    if it is all, I (maybe no one) can not detect morph file, from this log ^^;
    Usually if there is duplicate Formula erroer I may need only check log file, and serch the morph.
    (you can clear log file (delete all) once, then re-load the scene, or genesis2female, it may show only log
    about the scene loading I think though)
    then I think duplicate formula have some patterns, but if you feel it is caused by genX morph,
    simply move all morphs in (your daz content root )/data/DAZ 3D/Genesis2/Female(Male)/Morphs/D3D Gen X/Genesis/)
    to somewhere out of your content directory, (then ds can not find them any more,,)
    then load gen2female, again.
    if it work, you may need to return each file one by one, and find which morph cause duplicate.
    (I feel some product morph which you have already for gen2female, conflict with generation X2 transfered morph
    eg genesis shape or reagcy shape for genesis2 etc, )
    then ,,,it is just advice,,
    as genX2 pdf said,,, you may better not transfer many morphs at once, untill you udnerstand
    how this tool work , may try one morph , and check which files are generated ^^
    Post edited by kitakoredaz on
