The Viewport is gone from my DAZ3D in the middle.. (Have picture)
foxyfoxfurriesfoxyfoxfurries Posts: 394
edited June 2022 in Daz Studio Discussion
Hi
I always had the Viewport on the middle when I make motions but now its dissapear any one know maybe how can I bring it back?...
Thnaks :)
EDIT : I try to fix it and now my panels in the left are gone to -.- PLEASE HELP
1311 x 1012 - 55K
1920 x 1079 - 127K
Post edited by foxyfoxfurries on
  • felisfelis Posts: 6,583
    What happens if you go to Windows > Workspace > Select Layout and select a layout?
     I use pane and now I found them all , but how I pin them to the right side like they was? And thanks BTW
    1919 x 1013 - 140K
  • IceCrMnIceCrMn Posts: 2,334
    Can reopen it.
    Window>Panes>Viewport
    Use mouse pointer to grab the frame near the little tab on it.Then position it where you want it and drop it.
    The area it will connect to should turn a different color so you can see where it's going to attach itself when you let it go.
  • IceCrMn said:
    Can reopen it.
    With what felis tell me it also work but I do with the Panes and I found them all , but how can I pin them to the right side like they was? I dont want make stupid things again I dont have power to search again lol...
    1919 x 1013 - 140K
    I think you can move the whole block to the right, and when a yellow line shows up drop it.
    When you get your layout back, you can save it, so if anything happens again you can reload it.
    Window>WorkSpace>Select Layout
    Looks like you were using one of the "City Limits" layouts.
    Click it to get that pane group back on the right side.
    Once you have everything just like you want.
    Save your layout and your style.
    For workspace...
    Window>Workspace>Save Layout
    For Style...
    Window>Style>Save Style as
    When saved, you can fix either one or both if they get messed up.
    This works also, can be a bit difficult to hit the side frame of the viewport, but very much can be done.
    Thank you very much!!! Your the best!
    For workspace...
    For Style...
