Merge geometry question
Hi. I've got several primitives I'd like to merge using the Geometry Editor. Sometimes I get the error "This action requires a selected TriAx figure in the scene, with geometry and one or more followers." I presume that means I have to convert the primitive objects into TriAx figures, but when I do that, the primitives' scale and morphs go haywire. I recognize the shapes they revert to as being an earlier stage of design, but I can't possibly remember all the tweaks I did to them between whatever stage that was and now.  Is there a convenient way to restore or counteract whatever the conversion process does to them?
Is it safe to assume the error means the followers also have to be TriAx figures?
  • Richard HaseltineRichard Haseltine Posts: 111,374
    If you just want to turn a bunch of items into a single, static object the solution would be export as OBJ and reimport, using the same preset in both directions (probably the Daz Studio one). Merge geoemtry is for creating a compound figure, I think - it's not a feature I have ever used.
