Problem with Transfer Utility
Hi. Need clothing for use in Unity3D (i.e. with bones). I made a t-shirt in Marvelous. Then in .obj and in DAZ. Get dressed - dressed, but after the transfer "breaks". Moreover, if you do it in T-pose, the transfer is obtained without problems.  What am I doing wrong?
  • FeralFeyFeralFey Posts: 3,948
    @pahomovie23 -
    1. Describe "breaks".
    2. When you're creating the t-shirt in MD, is the avatar you're using in the "A" pose or the "T" pose? Because that does affect the final outcome when using the transfer utility.
    3. What figure are you using to load the t-shirt onto in DS? Because this will also mess with the transfer utility if you're trying to apply an outfit on a figure that is in the opposite pose ("A" or "T") that the outfit was created in. It's not impossible, but there can be some wonkiness.
