autofit not working right
Strobe_LightStrobe_Light Posts: 264
So when I go to put a g3f hair on g8f it will have the option to chose the figure it was meant for but the option for what the item is isn't changable so it's stuck on none.
For example you can't click on the none:
Post edited by Strobe_Light on
  • FSMCDesignsFSMCDesigns Posts: 12,855
    i would suggest never using autofit for hair unless it is very short as it can cause all kinds of issues. try changing the scene identifier instead and then fit normally and see if that helps. If nothing else, just position into place and parent it instaed of fit to.
    846 x 378 - 69K
  • Strobe_LightStrobe_Light Posts: 264
    autofit is doing this with everything even clothes and that method didnt work.
    Autofit requires that the CMS be running.
  • UHFUHF Posts: 518
    Often hair or anything can just be told to fit from G3 to G8, and it will just work with no issues, including shoes (but you may need to morph\pose the feet by hand).
    Load a base G8, make sure its not selected, then load in what you want.
    Edit->Scene Identification
    Set;
    Compatibility Base to the original figure.
    Autofit Base to the original figure.
    Prefered Base to the your current figure.
    You can now just change the Fit To parameter to the current figure, and it will just work.  It should also follow as you morph.
    You can then save the fitted clothes as figure support assets, and reuse them like you normally do.
    Over the years, I've had lots of issues with hair, and its not autofit.  Some hair just doesn't play nice with the figure's mesh.
    So i found the issue. The figure I was trying to fit it to was converted from genesis 3 so now I will fit the hair to a base g8f first and then to my figure.
