Kids Zone Mini Park
In DIM, Kids Zone Mini Park is listed as Part 1 of 2.
Part 2 doesn't show up for download unless I have Poser files selected in my download filter.
Is this how Poser files now show up in DIM? Or is this an error?
    probably an error since I see nothing about poser in the description. might need to contact CS to sort it out instead of posting in the forums
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,491
    Petipet usually has Poser files so the omission is likely a mistake in the description too
  • NorthOf45NorthOf45 Posts: 5,896
    Part 2 is the Poser version (runtime\geometries\, runtime\libraries\characters\, etc.), although there is no indication of that in the description, in DIM, or even in the Product Library where the files are listed. The Readme file list only shows the contents of the first package. Asleep at the switch.
  • Jason GalterioJason Galterio Posts: 2,562
    Thanks for the feedback.
    I can confirm that I only needed to install Part 1 when using in DS. It loaded and rendered with no issues.
  • solissolis Posts: 124
    If it wasn't for this thread I wouldn't have know about not needing Part 2. That info should definitely be in the product's description.
    I couldn't even FIND Part 2 until I mucked about with my DIM settings.
     It is actually tagged Poser 9+, but you can't see the tag until you download it, and if you filter out Poser 9+, you'll never know...
    Exactly.
    I had my DIM set for just DS... but I have noticed some odd ball products turning up only in Private Build or one of the other settings I don't normally use. Turning on the Poser options was the last resort because I didn't see any mention of Poser compatibility.
