iRadiance Mega Outdoor Pack - 24 HDRIs With Advanced HDRI Tools
Hi, how do I align the bush shadow occluder, and which Pano environment is it for?
  • markusmaternmarkusmatern Posts: 614
    I think it works best with DTMO - Outdoor Pano F
    Here are some quick scenes with and without the DTMO - Bushes Shadow Occluder (Instances)
    For positioning I just changed the Y placement. I think depending on the render size you don't need to position it accurately.
    2560 x 1440 - 1M
    2560 x 1440 - 1M
    2560 x 1440 - 1M
  • ravenzvideoravenzvideo Posts: 41
    edited June 2022
    Ah, thanks a million!  It works perfectly &  looks so cool.
    Is it possible to make our own shadow occluder like the bush shadow occluder in Daz Studio?
    Post edited by ravenzvideo on
    edited June 2022
    You are welcome!
    Yes you can create the necessary properties yourself. Select the object that should work as a shadow catcher and in your content library start a script called Scripts\Utilities\Create Advanced Iray Node Properties
    This adds a property in the Parameters pane → Display → Rendering → Iray → Enable Iray Matte Set it to On to work as a shadow catcher.
    This example from my gallery uses a shadow catcher from the Iray HDRI Toolkit
    Post edited by markusmatern on
  • Wow, great art! You really captured a shared feeling and so much more and made it humorous.  Genius!
    Thanks for the shadow catcher help.  It is so interesting and magical.
    Thank you very much for your kind words!
    You are welcome!
