Tattoos do not show up in Scene tab
Title: Tattoos do not show up in Scene tab
I got this below product for adding tattoos to G8 figure. After I add these tattoos, I dont see them listed in the scene tab and as a result unable to remove them (other than using Ctrl Z, if ti was the last thing I did). How do I find it in the G8F after adding them and more importantly, how can i remove them from the figure?
https://www.daz3d.com/inked-vol-27-just-henna-for-genesis-8-females
Alos, when I double click on a tattoo, it takes about 3-4 seconds to apply and show in the viewport. Anyway to speed this up?
  • LeanaLeana Posts: 13,645
    Those are not separate items, so they can't appear in scene tab.
    They're material presets which add tattoo maps as an overlay to those used by some of the properties of the surfaces, using the layered image editor tool included in DS.
    They needs time to load as DS has to compute the result of overlaying the maps used for the tattoo on the ones from your figure.
    Thanks for the info. Is there a setting in the surfaces or layered image editor tool that i can use to remove the tattoo?
  • felisfelis Posts: 6,632
    They are added as Layered Images, i.e. you have to open the surface tab of the character, then find the relevant surface (e.g. torso) and then click on the image (probably base color) and select layered iamge editor.
    From there you can adjust it or remove it.
