Using an HDRI purely as a background
I don't think I've ever used HDRIs before, so I hope this is not a silly question! Can I use an HDRI purely as a nice background image? So more specifically...
- The dome is nice and bright.
- It is reflected in other surfaces in the scene, just as if it were a picture.
- It is not a source of light. The only things emitting light are the scene lights.
Thanks!
  • AgitatedRiotAgitatedRiot Posts: 4,766
    edited June 2022
    In this scene, I used an HDRI I set the environment intensity and Environment Map to .05 the other lights are from the emissions on the torch and lamps on the building. Everyone uses different tricks.
    1860 x 881 - 1M
    Post edited by AgitatedRiot on
  • AndrewJJPAndrewJJP Posts: 779
    Thanks, I'll give that a try smiley
  • rosselianirosseliani Posts: 516
    AFAIK an HDRI is always a source of light, am I wrong?
    That's why I wondered if it was a silly question wink
    I suppose more specifically, I would like a background like one of these or some other similar product...
    https://www.daz3d.com/bokeh-studio-hdr
    That's a nice set of backgrounds, but what I don't want is for stuff I can't see in front of the model to interfere with my lighting. In the past, I've used a primitive plane with a picture on it (which is of course lit by the scene lights). It was really just something that occurred to me as a thing that would be nice to do.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,647
    edited June 2022
    you can if you use Octane
    or for that matter 3Delight where you can texture a large sphere with it and have it not receive or cast shadows
    iray annoyingly doesn't allow non PBR options
  • Richard HaseltineRichard Haseltine Posts: 111,688
    You could apply the HDR to a sphere and just use it as a backdrop that way, but of course that would then be tricky to light.
    You are not.
    You are not.
    An HDR file can be used as an image, without emitting light, through the Surfaces pane
    You are not.
    Added to the knowledge base. Will it render as a background or black?
    edited June 2022
    You are not.
    You could add lights  inside the sphere
    Thanks to every one that replied! I will be trying out these today, although iRay is so integral to the look and feel of my gallery, I could never see myself changing that, interesting through the other engines are.
