Transfer Utility - No Projection Template
FuerchanFuerchan Posts: 63
Hello,
I use "Transfer Utility" for a dress. The problem is that the garment does not fit. The "Projection Template" being blocked "None". Unable to make a choice.
What is the reason?
thank you
F.
DS 4.6
  • Richard HaseltineRichard Haseltine Posts: 112,067
    Is the content management system working? Is the source figure one of the standard DAZ figures?
  • FuerchanFuerchan Posts: 63
    I would say yes. But how can I check it?
    The figure is Genesis
    F.
    Do you have any files in Smart Content, or under products or Categories in the Content Library?
    Hello,
    Yes: Accessories, Cameras, Environnent, Figures, Hair ... and their objects that appear.
    There, there is a list: Accessories, Anatomy, Animation, Cameras, Documents ... Some display images and other not displayed.
    Thank you
    F.
    OK, then the Content Management Service is working and you are suign a figure that should have content types. Do you have files with foldrs in \data\DAZ 3D\Genesis\Base\Projection Templates\ in your content directory (My DAZ 3D Library, or whatever you sue) if you use the OS browser to look?
    Yes, I have files in in \data\DAZ 3D\Genesis\Base\Projection Templates\
    Then I'm not sure what else to suggest. Sorry.
    I keep an open subject ...
    thank you :-)
    F.
