• Daz 3D
  • Shop
  • 3D Software
    • Daz Studio Premier
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
    • Game Ready
  • Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
  • Download Studio
  • Menu
  • Daz 3D
  • Shop
  • 3d Software
    • Daz Studio
    • Install Manager
    • Exporters
    • Daz to Roblox
    • Daz to Maya
    • Daz to Blender
    • Daz to Unreal
    • Daz to Unity
    • Daz to 3ds Max
    • Daz to Cinema 4D
  • 3D Models
    • Genesis 9
    • Genesis 8.1
    • Free 3D Models
  • Community
    • Our Community
    • Gallery
    • Forums
    • Blog
    • Press
    • Help
  • Memberships
    • Daz Premier
    • Daz Plus
    • Daz Base
    • Compare
  • AI Solutions
Notifications
Loading...
    • Categories
    • Recent Discussions
Daz 3D Forums > 3rd Party Software > Maya Discussion
Daz to maya not exporting environments and props?
videoninja719videoninja719 Posts: 344
May 2022 in Maya Discussion
Hi. I am trying to export props and environments sets from daz to maya, but when importing in Maya in doesnt import any environments or props, just characters hairs and clothing.
  • davegvdavegv Posts: 166
    July 2022 edited July 2022
    There used to be a option to select either the character+Props or just the character -  I don't know why this has been removed or no longer functioning perhaps somebody from the daz team can answer that question?
    Most props will go into Maya as a fbx export without using the bridge with no major issues... the original daztomaya Ver 1.0 from 3dToAll ( the original developer of the plugin ) still will import both the character and the prop as I recently tested it but only in a older version of maya ( 2019 - 2020 )
    if you update the original version here : https://www.3dtoall.com/daztomaya-update/
    I use Maya 2022 so it isn't part of my workflow, but i'd sure like to see that function back in the plugin.
    ////////// edit////////    I thought i should add that if you have a enviroment in Maya ( Via FBX ) you can then use DaztoMaya to merge your character into the scene. There is even a option on the DaztoMaya dialog to do so.
    i further noticed that in the DaztoMaya dialog where you select Static mesh or skeleton you can see that enviroment and pose are greyed out for some reason which is unknown to me and the entire subject of WHY? are they greyed out???
    Post edited by davegv on July 2022
  • Krys KryngleKrys Kryngle Posts: 319
    July 2022
    I think the developer had mentioned previously that the greyed out options are not enabled yet, but they are coming in future versions...:)
  • danielbui78danielbui78 Posts: 333
    @davegv Krys Kryngle is correct: the options are currently greyed out because that functionallity has not been fully implemented in the Maya plugin side yet.
    @videoninja719 Although environments are not seamlessly supported yet, you can still import most props and environments by selecting their sub-components.  Here is an example with the Hacienda Kitchen environment:
    1. Load the "Hacienda Kitchen With Accessories and Lights" Set
    2. In the Scene panel, open the "Hacienda Kitchen With Accessories" node to show the child nodes.  Notice that this node's icon is a cube with missing sides/edges.  This is a Group Node which is not yet supported by the DazToMaya bridge.
    3. Select "Hacienda Kitchen".
    4. Click File -> Send To -> Daz to Maya.  Click Accept.
    5. Open Maya.  Click the "DAZ IMPORT" icon in the DazToMaya shelf tab.  Click "Auto-Import" in the DazToMaya dialog.
    Repeat the above steps for other child nodes with props that you wish to export that are nested inside Group Nodes.
    2226 x 1288 - 555K
    2231 x 1356 - 326K
    Post edited by danielbui78 on July 2022
  • videoninja719videoninja719 Posts: 344
    August 2022
    thank you @danielbui78 this really helps
    February 2023
    everyting looks good in viewport. but when render in arnold everything becomes colorless-black and white
    February 2023
Adding to Cart…
Daz 3D is part of Tafi
Connect
DAZ Productions, Inc.
7533 S Center View Ct #4664
West Jordan, UT 84084
HELP
Contact Us
Tutorials
Help Center
Sell Your 3D Content
Affiliate Program
Documentation Center
Open Source
Consent Preferences
JOIN DAZ
Memberships
Blog
About Us
Press
Careers
Bridges
Community
In the Studio
Gallery
Forum
DAZ STORE
Shop
Freebies
Published Artists
