ViewPort Display Objects turn orange when moused over.
AVU4UAVU4U Posts: 67
When ever I mouse over objects in ViewPort all the objects turn orange. How can I turn this of?
    Hi, If you set "surface selection" or "Region navigation" tool as Active tool?
    it should turn mouse overed surfaces or regions color to "Accent color".
    Change tool to "node selection", or "univversal" .
    it turn color only about bounding box of nodes.
    Then If you want to change these "accent color"
    go to top menu >window>style>customize color.
    then change Accent color. (but it change all "Accent color" which you use in current style)
    1000 x 568 - 120K
  • Richard HaseltineRichard Haseltine Posts: 112,059
    If this is with a node selection tool - such as the Universal tool - then in DS 4.7 or earlier go to the Tool Settings pane, in DS 4.8 go to the Draw Settings pane (both Window>Panes(Tabs)) and make sure that Node Highlighting is set to Bounding Box only.
