Thalia for Coral 8.1 Broken
I purchased Coral and Thalia, but the maps/ tail for Thalia is broken.
-Upon loading Thalia Mermaid directly under 'Products' folder, her maps for 'Gils' under surfaces are not working no matter what skin I use. Please see pic attached- this is just a straight up load with no other changes, rendered in Iray. I can't even turn off the weird color thing because there is no opacity channel under surfaces 'Gils'. I tried the 'Gils' under the surface tab for both the base Coral tail and the Thalia tail. Neither seems to work. I have tried messing with the surface optins, but I am at a loss, and I generally know how to reskin textures...
-If I load Thalia Human and try to add the Thalia Tail Full, I get a weird mesh thing instead of a tail. Pic attached.
-If I load Thalia Human and add Coral tail, then try to add Thalia Tail Full, I also get the weird blocky mesh.
-When I load Thalia Human and add the Coral Tail then apply the Thalia Tail Cover Only, I get a weird overlay over the tail that doesn't work with the textures for Thalia.
All Coral products load and work correctly independantly of the Thalia product.
Is it just me? Please help.
  • LoreMistress IzariaLoreMistress Izaria Posts: 145
    edited May 2022
    The weird colors.
    1057 x 893 - 1015K
    Post edited by LoreMistress Izaria on
  • Here is the weird mesh
    1920 x 1080 - 291K
  • felisfelis Posts: 6,502
    That looks like missing geometry. What does your log say (Help > Troubleshooting > Log)?
  • Here is the log:
    2022-05-27 12:58:12.487 [INFO] :: Processing scene data...
    2022-05-27 12:58:12.487 [INFO] :: Finalizing modifiers...
    2022-05-27 12:58:12.487 [INFO] :: Finalizing channels...
    2022-05-27 12:58:12.488 [INFO] :: Finalizing materials...
    2022-05-27 12:58:12.488 [INFO] :: Sorting property groups...
    2022-05-27 12:58:12.490 [INFO] :: Finalizing scene data...
    2022-05-27 12:58:12.518 [INFO] :: Begin Loading Character Addons...
    2022-05-27 12:58:12.571 [INFO] :: Prepare asset load (merge): /data/DAZ 3D/Genesis 8/Female 8_1 Eyelashes/Tools/Script Loads/Genesis 8.1 Female Eyelashes.duf
    2022-05-27 12:58:12.571 [INFO] :: Locking viewport redraw...
    2022-05-27 12:58:12.571 [INFO] :: Viewport redraw locked.
    2022-05-27 12:58:12.579 [INFO] :: Native format content directories: 3
    2022-05-27 12:58:12.579 [INFO] :: Poser format content directories: 3
    2022-05-27 12:58:12.579 [INFO] :: Other import format content directories: 0
    2022-05-27 12:58:12.579 [INFO] :: Begin asset load (merge): /data/DAZ 3D/Genesis 8/Female 8_1 Eyelashes/Tools/Script Loads/Genesis 8.1 Female Eyelashes.duf
    2022-05-27 12:58:12.582 [INFO] :: Determining missing assets...
    2022-05-27 12:58:12.652 [INFO] :: Setting textures...
    2022-05-27 12:58:12.680 [INFO] :: Scanning for addons...
    2022-05-27 12:58:12.802 [INFO] :: Creating node geometry...
    2022-05-27 12:58:12.802 [INFO] :: Creating UV sets...
    2022-05-27 12:58:12.802 [INFO] :: Creating materials...
    2022-05-27 12:58:12.805 [INFO] :: Resolving legacy figures...
    2022-05-27 12:58:12.805 [INFO] :: Preparing modifiers...
    2022-05-27 12:58:12.806 [INFO] :: Creating modifiers...
    2022-05-27 12:58:12.810 [INFO] :: Creating sum stage formulas...
    2022-05-27 12:58:12.810 [INFO] :: Creating multiply stage formulas...
    2022-05-27 12:58:12.810 [INFO] :: Finalizing modifiers...
    2022-05-27 12:58:12.811 [INFO] :: Sorting property groups...
    2022-05-27 12:58:12.811 [INFO] :: Setting up follow targets...
    2022-05-27 12:58:12.812 [INFO] :: Start following: HS Thalia Mermaid << Genesis 8.1 Female Eyelashes
    2022-05-27 12:58:12.812 [INFO] :: Following started: HS Thalia Mermaid << Genesis 8.1 Female Eyelashes
    2022-05-27 12:58:12.812 [INFO] :: Connect base morphs: HS Thalia Mermaid << Genesis 8.1 Female Eyelashes
    2022-05-27 12:58:12.834 [INFO] :: Applying projection morphs...
    2022-05-27 12:58:12.842 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/Daz 3D/Genesis 8/Female 8_1 Eyelashes/Morphs/DAZ 3D/Base/bs_EyelashesCollapsed.dsf
    2022-05-27 12:58:12.843 [INFO] :: Creating morph projection map: HS Thalia Mermaid << Genesis 8.1 Female Eyelashes
    2022-05-27 12:58:12.856 [INFO] :: Base morphs connected: HS Thalia Mermaid << Genesis 8.1 Female Eyelashes
    2022-05-27 12:58:12.856 [INFO] :: Applying projection morphs...
    2022-05-27 12:58:12.856 [INFO] :: Creating morph projection map: HS Thalia Mermaid << Genesis 8.1 Female Eyelashes
    2022-05-27 12:58:12.867 [INFO] :: Finished asset load (merge): 0m 0.287s - /data/DAZ 3D/Genesis 8/Female 8_1 Eyelashes/Tools/Script Loads/Genesis 8.1 Female Eyelashes.duf
    2022-05-27 12:58:12.870 [INFO] :: Unlocking viewport redraw...
    2022-05-27 12:58:12.870 [INFO] :: Viewport redraw unlocked.
    2022-05-27 12:58:12.879 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/DAZ 3D/Genesis 8/Female/Morphs/DAZ 3D/Base/PHMMouthRealism_HD_div2.dsf
    2022-05-27 12:58:12.897 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/talena/Fox Nose & Mouth 1/PHMMouthRealism8_1_HD_div4.dsf
    2022-05-27 12:58:12.954 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/talena/Fox Nose & Mouth 1/PHMEyelashesLengthUpper.dsf
    2022-05-27 12:58:12.954 [INFO] :: Processing morph projection queue: HS Thalia Mermaid << Genesis 8.1 Female Eyelashes
    2022-05-27 12:58:12.960 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/talena/Fox Nose & Mouth 1/PHMEyelashesLengthLower.dsf
    2022-05-27 12:58:12.964 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/talena/Fox Nose & Mouth 1/PHMEyelashesCurl.dsf
    2022-05-27 12:58:12.973 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Handspan Studios/Thalia/PBM_HSThalia_Navel.dsf
    2022-05-27 12:58:12.990 [INFO] :: Loaded morph deltas: 0m 0.14s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Handspan Studios/Thalia/FHM_HSThaliaHead.dsf
    2022-05-27 12:58:13.020 [INFO] :: Loaded morph deltas: 0m 0.22s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Handspan Studios/Thalia/FBM_HSThaliaBody.dsf
    2022-05-27 12:58:13.026 [INFO] :: Loaded morph deltas: 0m 0.1s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/Handspan Studios/Thalia/PHM Thalia Iris.dsf
    2022-05-27 12:58:13.030 [INFO] :: Morph projection queue processed: HS Thalia Mermaid << Genesis 8.1 Female Eyelashes
    2022-05-27 12:58:13.036 [INFO] :: Loaded morph deltas: 0m 0.2s - /data/Daz 3D/Genesis 8/Female 8_1/Morphs/talena/Fox Nose & Mouth 1/PBMNavel.dsf
    2022-05-27 12:58:13.066 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/Daz 3D/Genesis 8/Female 8_1 Eyelashes/Morphs/DAZ 3D/Base/bs_EyelashesTopPoint.dsf
    2022-05-27 12:58:13.073 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/Daz 3D/Genesis 8/Female 8_1 Eyelashes/Morphs/DAZ 3D/Base/bs_EyelashesSkewIrregularUpper.dsf
    2022-05-27 12:58:13.082 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/Daz 3D/Genesis 8/Female 8_1 Eyelashes/Morphs/DAZ 3D/Base/bs_EyelashesLengthIrregularUpper.dsf
    2022-05-27 12:58:13.094 [INFO] :: Loaded morph deltas: 0m 0.9s - /data/Daz 3D/Genesis 8/Female 8_1 Eyelashes/Morphs/DAZ 3D/Base/bs_EyelashesHeightUniformUpper.dsf
    2022-05-27 12:58:13.103 [INFO] :: Loaded morph deltas: 0m 0.8s - /data/Daz 3D/Genesis 8/Female 8_1 Eyelashes/Morphs/DAZ 3D/Base/bs_EyelashesHeightUniformLower.dsf
    2022-05-27 12:58:13.111 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/Daz 3D/Genesis 8/Female 8_1 Eyelashes/Morphs/DAZ 3D/Base/bs_EyelashesCurlUniformUpper.dsf
    2022-05-27 12:58:13.118 [INFO] :: Loaded morph deltas: 0m 0.6s - /data/Daz 3D/Genesis 8/Female 8_1 Eyelashes/Morphs/DAZ 3D/Base/bs_EyelashesCurlIrregularLowerPoint.dsf
    2022-05-27 12:58:13.182 [INFO] :: Prepare asset load (merge): /data/DAZ 3D/Genesis 8/Female 8_1 Tear/Tools/Script Loads/Genesis 8.1 Female Tear.duf
    2022-05-27 12:58:13.182 [INFO] :: Locking viewport redraw...
    2022-05-27 12:58:13.182 [INFO] :: Viewport redraw locked.
    2022-05-27 12:58:13.188 [INFO] :: Native format content directories: 3
    2022-05-27 12:58:13.188 [INFO] :: Poser format content directories: 3
    2022-05-27 12:58:13.188 [INFO] :: Other import format content directories: 0
    2022-05-27 12:58:13.188 [INFO] :: Begin asset load (merge): /data/DAZ 3D/Genesis 8/Female 8_1 Tear/Tools/Script Loads/Genesis 8.1 Female Tear.duf
    2022-05-27 12:58:13.192 [INFO] :: Determining missing assets...
    2022-05-27 12:58:13.229 [INFO] :: Setting textures...
    2022-05-27 12:58:13.254 [INFO] :: Scanning for addons...
    2022-05-27 12:58:13.561 [INFO] :: Creating node geometry...
    2022-05-27 12:58:13.562 [INFO] :: Creating UV sets...
    2022-05-27 12:58:13.562 [INFO] :: Creating materials...
    2022-05-27 12:58:13.575 [INFO] :: Resolving legacy figures...
    2022-05-27 12:58:13.575 [INFO] :: Preparing modifiers...
    2022-05-27 12:58:13.576 [INFO] :: Creating modifiers...
    2022-05-27 12:58:13.581 [INFO] :: Finalizing modifiers...
    2022-05-27 12:58:13.581 [INFO] :: Finalizing channels...
    2022-05-27 12:58:13.581 [INFO] :: Finalizing materials...
    2022-05-27 12:58:13.581 [INFO] :: Sorting property groups...
    2022-05-27 12:58:13.581 [INFO] :: Setting up follow targets...
    2022-05-27 12:58:13.581 [INFO] :: Start following: HS Thalia Mermaid << Genesis 8.1 Female Tear
    2022-05-27 12:58:13.581 [INFO] :: Following started: HS Thalia Mermaid << Genesis 8.1 Female Tear
    2022-05-27 12:58:13.581 [INFO] :: Connect base morphs: HS Thalia Mermaid << Genesis 8.1 Female Tear
    2022-05-27 12:58:13.591 [INFO] :: Applying projection morphs...
    2022-05-27 12:58:13.601 [INFO] :: Loaded morph deltas: 0m 0.10s - /data/Daz 3D/Genesis 8/Female 8_1 Tear/Morphs/DAZ 3D/Base/bs_TearProjectionShape.dsf
    2022-05-27 12:58:13.602 [INFO] :: Creating morph projection map: HS Thalia Mermaid << Genesis 8.1 Female Tear
    2022-05-27 12:58:13.613 [INFO] :: Base morphs connected: HS Thalia Mermaid << Genesis 8.1 Female Tear
    2022-05-27 12:58:13.613 [INFO] :: Applying projection morphs...
    2022-05-27 12:58:13.613 [INFO] :: Creating morph projection map: HS Thalia Mermaid << Genesis 8.1 Female Tear
    2022-05-27 12:58:13.623 [INFO] :: Finished asset load (merge): 0m 0.435s - /data/DAZ 3D/Genesis 8/Female 8_1 Tear/Tools/Script Loads/Genesis 8.1 Female Tear.duf
    2022-05-27 12:58:13.626 [INFO] :: Unlocking viewport redraw...
    2022-05-27 12:58:13.626 [INFO] :: Viewport redraw unlocked.
    2022-05-27 12:58:13.684 [INFO] :: Prepare asset load (merge): /data/Handspan Studios/HS Thalia/HS Thalia - Human Base.duf
    2022-05-27 12:58:13.684 [INFO] :: Locking viewport redraw...
    2022-05-27 12:58:13.684 [INFO] :: Viewport redraw locked.
    2022-05-27 12:58:13.685 [INFO] :: Processing morph projection queue: HS Thalia Mermaid << Genesis 8.1 Female Tear
    2022-05-27 12:58:13.695 [INFO] :: Morph projection queue processed: HS Thalia Mermaid << Genesis 8.1 Female Tear
    2022-05-27 12:58:13.700 [INFO] :: Native format content directories: 3
    2022-05-27 12:58:13.700 [INFO] :: Poser format content directories: 3
    2022-05-27 12:58:13.700 [INFO] :: Other import format content directories: 0
    2022-05-27 12:58:13.700 [INFO] :: Begin asset load (merge): /data/Handspan Studios/HS Thalia/HS Thalia - Human Base.duf
    2022-05-27 12:58:13.765 [INFO] :: Determining missing assets...
    2022-05-27 12:58:14.648 [INFO] :: Setting textures...
    2022-05-27 12:58:14.652 [INFO] :: Creating materials...
    2022-05-27 12:58:14.672 [INFO] :: Applying animations...
    2022-05-27 12:58:14.924 [INFO] :: Setting up follow targets...
    2022-05-27 12:58:14.924 [INFO] :: Finished asset load (merge): 0m 1.224s - /data/Handspan Studios/HS Thalia/HS Thalia - Human Base.duf
    2022-05-27 12:58:14.931 [INFO] :: Unlocking viewport redraw...
    2022-05-27 12:58:14.931 [INFO] :: Viewport redraw unlocked.
    2022-05-27 12:58:14.942 [INFO] :: Prepare asset load (merge): /data/DAZ 3D/Coral 8_1/Coral 8_1 Tail/Tools/Script Loads/Coral8_1Tail.duf
    2022-05-27 12:58:14.942 [INFO] :: Locking viewport redraw...
    2022-05-27 12:58:14.942 [INFO] :: Viewport redraw locked.
    2022-05-27 12:58:14.947 [INFO] :: Native format content directories: 3
    2022-05-27 12:58:14.948 [INFO] :: Poser format content directories: 3
    2022-05-27 12:58:14.948 [INFO] :: Other import format content directories: 0
    2022-05-27 12:58:14.948 [INFO] :: Begin asset load (merge): /data/DAZ 3D/Coral 8_1/Coral 8_1 Tail/Tools/Script Loads/Coral8_1Tail.duf
    2022-05-27 12:58:14.950 [INFO] :: Determining missing assets...
    2022-05-27 12:58:15.208 [INFO] :: Setting textures...
    2022-05-27 12:58:15.222 [INFO] :: Scanning for addons...
    2022-05-27 12:58:15.246 [INFO] :: Creating node geometry...
    2022-05-27 12:58:15.248 [INFO] :: Creating UV sets...
    2022-05-27 12:58:15.248 [INFO] :: Creating materials...
    2022-05-27 12:58:23.416 [INFO] :: Resolving legacy figures...
    2022-05-27 12:58:23.416 [INFO] :: Preparing modifiers...
    2022-05-27 12:58:23.416 [INFO] :: Creating modifiers...
    2022-05-27 12:58:23.419 [INFO] :: Creating sum stage formulas...
    2022-05-27 12:58:23.421 [INFO] :: Creating multiply stage formulas...
    2022-05-27 12:58:23.421 [INFO] :: Finalizing modifiers...
    2022-05-27 12:58:23.421 [INFO] :: Sorting property groups...
    2022-05-27 12:58:23.421 [INFO] :: Setting up follow targets...
    2022-05-27 12:58:23.421 [INFO] :: Start following: HS Thalia Mermaid << Coral 8.1 Tail
    2022-05-27 12:58:23.421 [INFO] :: Following started: HS Thalia Mermaid << Coral 8.1 Tail
    2022-05-27 12:58:23.421 [INFO] :: Connect base morphs: HS Thalia Mermaid << Coral 8.1 Tail
    2022-05-27 12:58:23.430 [INFO] :: Creating morph projection map: HS Thalia Mermaid << Coral 8.1 Tail
    2022-05-27 12:58:23.431 [INFO] :: Base morphs connected: HS Thalia Mermaid << Coral 8.1 Tail
    2022-05-27 12:58:23.432 [INFO] :: Creating morph projection map: HS Thalia Mermaid << Coral 8.1 Tail
    2022-05-27 12:58:23.446 [INFO] :: Finished asset load (merge): 0m 8.498s - /data/DAZ 3D/Coral 8_1/Coral 8_1 Tail/Tools/Script Loads/Coral8_1Tail.duf
    2022-05-27 12:58:23.450 [INFO] :: Unlocking viewport redraw...
    2022-05-27 12:58:23.450 [INFO] :: Viewport redraw unlocked.
    2022-05-27 12:58:23.464 [INFO] :: Loaded morph deltas: 0m 0.7s - /data/DAZ 3D/Coral 8_1/Coral 8_1 Tail/Morphs/Handspan Studios/Thalia/PBM_HSThalia_Gills.dsf
    2022-05-27 12:58:23.489 [INFO] :: Loaded morph deltas: 0m 0.10s - /data/DAZ 3D/Coral 8_1/Coral 8_1 Tail/Morphs/DAZ 3D/Base/TailHDLv5.dsf
    2022-05-27 12:58:23.890 [INFO] :: Loaded morph deltas: 0m 0.18s - /data/DAZ 3D/Coral 8_1/Coral 8_1 Tail/Morphs/DAZ 3D/Base/PBMNavel.dsf
    2022-05-27 12:58:23.890 [INFO] :: Processing morph projection queue: HS Thalia Mermaid << Coral 8.1 Tail
    2022-05-27 12:58:23.946 [INFO] :: Morph projection queue processed: HS Thalia Mermaid << Coral 8.1 Tail
    2022-05-27 12:58:24.001 [INFO] :: Prepare asset load (merge): /People/Genesis 8 Female/Characters/HS Thalia/Anatomy/HS Thalia Tail (Cover Only).duf
    2022-05-27 12:58:24.001 [INFO] :: Locking viewport redraw...
    2022-05-27 12:58:24.001 [INFO] :: Viewport redraw locked.
    2022-05-27 12:58:24.007 [INFO] :: Native format content directories: 3
    2022-05-27 12:58:24.007 [INFO] :: Poser format content directories: 3
    2022-05-27 12:58:24.007 [INFO] :: Other import format content directories: 0
    2022-05-27 12:58:24.008 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Characters/HS Thalia/Anatomy/HS Thalia Tail (Cover Only).duf
    2022-05-27 12:58:24.021 [INFO] :: Determining missing assets...
    2022-05-27 12:58:24.298 [INFO] :: Setting textures...
    2022-05-27 12:58:24.302 [INFO] :: Scanning for addons...
    2022-05-27 12:58:24.302 [INFO] :: Creating node geometry...
    2022-05-27 12:58:24.305 [INFO] :: Creating materials...
    2022-05-27 12:58:24.379 [INFO] :: Resolving legacy figures...
    2022-05-27 12:58:24.379 [INFO] :: Preparing modifiers...
    2022-05-27 12:58:24.380 [INFO] :: Creating modifiers...
    2022-05-27 12:58:24.380 [INFO] :: Finalizing modifiers...
    2022-05-27 12:58:24.380 [INFO] :: Sorting property groups...
    2022-05-27 12:58:24.380 [INFO] :: Setting up follow targets...
    2022-05-27 12:58:24.662 [INFO] :: Finished asset load (merge): 0m 0.655s - /People/Genesis 8 Female/Characters/HS Thalia/Anatomy/HS Thalia Tail (Cover Only).duf
    2022-05-27 12:58:24.663 [INFO] :: Unlocking viewport redraw...
    2022-05-27 12:58:24.663 [INFO] :: Viewport redraw unlocked.
    2022-05-27 12:58:24.742 [INFO] :: Prepare asset load (merge): /data/Handspan Studios/HS Thalia/HS Thalia - Human Base.duf
    2022-05-27 12:58:24.742 [INFO] :: Locking viewport redraw...
    2022-05-27 12:58:24.742 [INFO] :: Viewport redraw locked.
    2022-05-27 12:58:24.746 [INFO] :: Native format content directories: 3
    2022-05-27 12:58:24.746 [INFO] :: Poser format content directories: 3
    2022-05-27 12:58:24.746 [INFO] :: Other import format content directories: 0
    2022-05-27 12:58:24.746 [INFO] :: Begin asset load (merge): /data/Handspan Studios/HS Thalia/HS Thalia - Human Base.duf
    2022-05-27 12:58:24.809 [INFO] :: Determining missing assets...
    2022-05-27 12:58:25.444 [INFO] :: Setting textures...
    2022-05-27 12:58:25.446 [INFO] :: Creating materials...
    2022-05-27 12:58:25.480 [INFO] :: Applying animations...
    2022-05-27 12:58:25.803 [INFO] :: Setting up follow targets...
    2022-05-27 12:58:25.803 [INFO] :: Finished asset load (merge): 0m 1.56s - /data/Handspan Studios/HS Thalia/HS Thalia - Human Base.duf
    2022-05-27 12:58:25.812 [INFO] :: Unlocking viewport redraw...
    2022-05-27 12:58:25.812 [INFO] :: Viewport redraw unlocked.
    2022-05-27 12:58:26.118 [INFO] :: Prepare asset load (merge): /People/Genesis 8 Female/Characters/HS Thalia/Anatomy/HS Thalia Brows.duf
    2022-05-27 12:58:26.118 [INFO] :: Locking viewport redraw...
    2022-05-27 12:58:26.118 [INFO] :: Viewport redraw locked.
    2022-05-27 12:58:26.121 [INFO] :: Native format content directories: 3
    2022-05-27 12:58:26.121 [INFO] :: Poser format content directories: 3
    2022-05-27 12:58:26.121 [INFO] :: Other import format content directories: 0
    2022-05-27 12:58:26.121 [INFO] :: Begin asset load (merge): /People/Genesis 8 Female/Characters/HS Thalia/Anatomy/HS Thalia Brows.duf
    2022-05-27 12:58:26.129 [INFO] :: Determining missing assets...
    2022-05-27 12:58:26.159 [INFO] :: Setting textures...
    2022-05-27 12:58:26.186 [INFO] :: Scanning for addons...
    2022-05-27 12:58:26.195 [INFO] :: Creating node geometry...
    2022-05-27 12:58:26.196 [INFO] :: Creating UV sets...
    2022-05-27 12:58:26.196 [INFO] :: Creating materials...
    2022-05-27 12:58:26.204 [INFO] :: Resolving legacy figures...
    2022-05-27 12:58:26.204 [INFO] :: Preparing modifiers...
    2022-05-27 12:58:26.204 [INFO] :: Creating modifiers...
    2022-05-27 12:58:26.205 [INFO] :: Finalizing modifiers...
    2022-05-27 12:58:26.205 [INFO] :: Sorting property groups...
    2022-05-27 12:58:26.205 [INFO] :: Setting up follow targets...
    2022-05-27 12:58:26.205 [INFO] :: Start following: HS Thalia Mermaid << HS Thalia Brows
    2022-05-27 12:58:26.206 [INFO] :: Following started: HS Thalia Mermaid << HS Thalia Brows
    2022-05-27 12:58:26.206 [INFO] :: Connect base morphs: HS Thalia Mermaid << HS Thalia Brows
    2022-05-27 12:58:26.212 [INFO] :: Creating morph projection map: HS Thalia Mermaid << HS Thalia Brows
    2022-05-27 12:58:26.214 [INFO] :: Base morphs connected: HS Thalia Mermaid << HS Thalia Brows
    2022-05-27 12:58:26.214 [INFO] :: Creating morph projection map: HS Thalia Mermaid << HS Thalia Brows
    2022-05-27 12:58:26.216 [INFO] :: Finished asset load (merge): 0m 0.94s - /People/Genesis 8 Female/Characters/HS Thalia/Anatomy/HS Thalia Brows.duf
    2022-05-27 12:58:26.218 [INFO] :: Unlocking viewport redraw...
    2022-05-27 12:58:26.218 [INFO] :: Viewport redraw unlocked.
    2022-05-27 12:58:26.228 [INFO] :: Loaded morph deltas: 0m 0.9s - /data/Handspan Studios/HS Thalia/HS Thalia Brows/Morphs/Handspan Studios/Base/Base.dsf
    2022-05-27 12:58:26.292 [INFO] :: Prepare asset load (merge): /data/Handspan Studios/HS Thalia/HS Thalia - Human Base.duf
    2022-05-27 12:58:26.292 [INFO] :: Locking viewport redraw...
    2022-05-27 12:58:26.292 [INFO] :: Viewport redraw locked.
    2022-05-27 12:58:26.298 [INFO] :: Native format content directories: 3
    2022-05-27 12:58:26.298 [INFO] :: Poser format content directories: 3
    2022-05-27 12:58:26.298 [INFO] :: Other import format content directories: 0
    2022-05-27 12:58:26.298 [INFO] :: Begin asset load (merge): /data/Handspan Studios/HS Thalia/HS Thalia - Human Base.duf
    2022-05-27 12:58:26.360 [INFO] :: Determining missing assets...
    2022-05-27 12:58:26.771 [INFO] :: Setting textures...
    2022-05-27 12:58:26.773 [INFO] :: Creating materials...
    2022-05-27 12:58:26.809 [INFO] :: Applying animations...
    2022-05-27 12:58:27.151 [INFO] :: Setting up follow targets...
    2022-05-27 12:58:27.151 [INFO] :: Finished asset load (merge): 0m 0.853s - /data/Handspan Studios/HS Thalia/HS Thalia - Human Base.duf
    2022-05-27 12:58:27.152 [INFO] :: Processing morph projection queue: HS Thalia Mermaid << HS Thalia Brows
    2022-05-27 12:58:27.164 [INFO] :: Morph projection queue processed: HS Thalia Mermaid << HS Thalia Brows
    2022-05-27 12:58:27.172 [INFO] :: Unlocking viewport redraw...
    2022-05-27 12:58:27.172 [INFO] :: Viewport redraw unlocked.
    2022-05-27 12:58:27.176 [INFO] :: Finished Loading Character Addons
    2022-05-27 12:58:27.220 [INFO] :: Finished asset load (open): 0m 50.490s - /People/Genesis 8 Female/Characters/HS Thalia Mermaid.duf
    2022-05-27 12:58:28.368 [INFO] :: Unlocking viewport redraw...
    2022-05-27 12:58:28.368 [INFO] :: Viewport redraw unlocked.
    2022-05-27 12:58:28.674 [INFO] :: Loaded image: HS_Thalia_Gills_Base.png
    2022-05-27 12:58:28.847 [INFO] :: Loaded image: HS_Thalia_Tail_Base.png
    2022-05-27 12:58:29.020 [INFO] :: Loaded image: 07_HS_Thalia_Eyes_Base.png
    2022-05-27 12:58:29.276 [INFO] :: Loaded image: 05_HS_Thalia_Arms_Base.png
    2022-05-27 12:58:29.456 [INFO] :: Loaded image: 06_HS_Thalia_Mouth_Base.png
    2022-05-27 12:58:29.719 [INFO] :: Loaded image: 01_HS_Thalia_Face_Base.png
    2022-05-27 12:58:29.914 [INFO] :: Loaded image: 02_HS_Thalia_Head_Base.png
    2022-05-27 12:58:30.188 [INFO] :: Loaded image: 01_HS_Thalia_Face_Base_NB.png
    2022-05-27 12:58:30.411 [INFO] :: Loaded image: 03_HS_Thalia_Body_Base.png
    2022-05-27 12:58:30.967 [INFO] :: Loaded image: 11_HS_Thalia_Lashes_Cut.png
    2022-05-27 12:58:30.991 [INFO] :: Loaded image: 10_HS_Thalia_Tear_Cut.png
    2022-05-27 12:58:31.230 [INFO] :: Loaded image: HS_Thalia_Fins_Base.png
    2022-05-27 12:58:31.327 [INFO] :: Loaded image: HS_Thalia_Fins_Trans01.png
    2022-05-27 12:58:31.443 [INFO] :: Loaded image: HS_Thalia_Fins_Trans02.png
    2022-05-27 12:58:31.643 [INFO] :: Loaded image: HS_Thalia_Gills_Base03.png
    2022-05-27 12:58:31.781 [INFO] :: Loaded image: HS_Thalia_Gills_Cut2.png
    2022-05-27 12:58:32.119 [INFO] :: Loaded image: HS_Thalia_Tail_Base03.png
    2022-05-27 12:58:32.279 [INFO] :: Loaded image: Tail_Alt_Cut.png
    I don't see any errors or missing geometry...
    I can see it loads the tail via scripts.
    Can you load Coral 8.1 with tail without issues?
    Yes. I can load Coral 8.1 no problem. I also have CC Amarine for Coral, and all her parts and mats load just fine, too.
