Super Quick & Easy DS Iray Tricks - Dreamlight - where are they?
rogerjhardy100rogerjhardy100 Posts: 297
I downloaded Dreamlight's Super Quick & Easy DS Iray Tricks via DAZ Install Manager but now cannot find them. Or, I shoud say, I've found them under My 3D Library>General>Dreamlight and have links to the MP4 and WMV but nothing happens when I click on them. Where can I find these files so I can open them?
  • BeeMKayBeeMKay Posts: 7,019
    edited May 2015
    In your content directory, in the subfolder:
    My DAZ 3D Library\General\Dreamlight
    You can't start them through DS, but you have to go there and start them manually.
    EDIT: Actually, thinking about it, you can go there by Right-clicking on the folder name in DS, then select "go to Folder Location" in the dropdown menu that opens. It will open a new browser window leading you right to the location.
    Post edited by BeeMKay on
    Then if the link file of Content library was broken,
    you can serch installed files by DIM too.
    I usually serch tutorialls by DIM.
    DIM>installed section> On the product record, right click>show installed files.
    it should show MP4 or pdf (I do not know) ,if it was insalled.
    and you can open file explore by direct link of each files.
    903 x 561 - 86K
  • rogerjhardy100rogerjhardy100 Posts: 297
    Thanks everyone. Found them!
