The Streets of NYC
I have purchased Stonemason's The Streets of NYC but it doesn't come up at all in Content or Smart Content tabs. I have tried to uninstall and reinstall several times, and even uninstalled and reinstalled other content at the same time as a control. The other things I have reinstalled come up fine but The Streets of NYC is a no show. Are there any known issues with this product or its installer?
Thanks much for any help.
Post edited by Costello on
Greetings,
It's an older product; pull up DAZ Install Manager, go to your Installed list, select Streets of NYC (I presume Townhouse Row), then you can right-click (IIRC) or click the button at the end, and select 'Show Installed Files', and that'll give you a hint where it showed up.
It's very possible it's in Poser Format/My Library/Props, for instance... I don't have the info in front of me (not at home), so I can't tell you exactly where it is.
-- Morgan
That worked nicely. Thanks!
