SOLVED How do i uninstall Realty?
Serene NightSerene Night Posts: 17,705
Hi:
I bought the plugin through the store, but can't use it because my machine isn't robust enough. How can I remove it? It is creating Realtiy Scene Data files in some of my saved progects, one of which now has 3176 files. I don't use it, and would like it to be gone. Any advice?
    If you installed using DIM, it should be as simple as going to the Installed tab, and uninstalling it from there. Make sure that DS is closed, and then restart it, and hopefully it will be gone.
    Of course, DIM doesn't install it. I found the answer at RDNA for you, the link below should tell you how
    http://preta3d.com/wiki/doku.php?id=uninstalling_reality_4_studio_edition
    Thanks for trying to help. =-)
    I found the folder and deleted it but DAZ 3d still wants to access that folder every time I boot DAZ up. (see screenshot 1).
    Reality has also created MANY temp files in some of my old files even though I never was using it. I wonder if there is a way to remove it for good?
    644 x 484 - 62K
    334 x 835 - 64K
    Thanks for your help. I found it by searching my c drive, the plugin is removed and I no longer get the error. GRAS! =-)
