Is there any technique to make Buck's hair/fur look more like hair/fur?
I did try with uhd fur builder without much success, is there a way to use it that I am missing, all I did was click a fur icon but it really didnt resemble fur or deer skin hair
thanks
https://www.daz3d.com/buck
  • Richard HaseltineRichard Haseltine Posts: 111,482
    That is a really old product - a three digit SKU. You could try adding strand-based hair, but there are more recent deer figuers that might be worth looking at.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,591
    edited May 2022
    I don't own him but he is ancient, likely very lowpoly
    any displacement fur shader would have very little to work with
    you may be able to add some strandbased hair to him or LAMH if you own it if using 3Delight
    I think a newer buck would be a better choice, there are several here and elsewhere
    I don't have Tane but he looks good
  • VicSVicS Posts: 1,273
    Thanks Wendy
  • NorthOf45NorthOf45 Posts: 5,901
    UHD Fur Builder needs a lot of experimentation to get decent results. Keep trying. Watch the video.
    Oso Fur Shaders for Iray uses a different technique. It will also need some experimentation. There is a ReadMe.
    edited May 2022
    Oso Fur looks interesting- I never saw it before, if you have used both of them which one would you say-
    1-gets better fur/hair results
    2-which one of the two is easier to use
    thanks North
    New developement I was loading Buck then slecting it and loading "Buck Map" but the right way is just load "Buck Map" and it doesnt look so bad, luckily I had done that in a render from a while ago that I noticed and tried it again
    (when I click on the image of the bucks it opens very large but if I minimize the browser t o50% it gets back to normal size so it doesnt look all mushy like whe it is blown up double
    929 x 959 - 2M
    Post edited by VicS on
    They are equally frustrating to get realistic looking results. Not so good up close, but at a distance, not too bad. Oso Fur uses generated displacement, so it tends to look kind of spiky at lower resolutions. But, it is sometimes good to have options.
    Ok I wouldnt want to deal with somehting like that, thank you- it's always nice to know beforehand
    they should have these listed as frustrating harder to use products on the promos LOL
