Skin Doctor Wet and Wild support for non-DAZ female gens?
Hello -
Would anyone happen to know if it's possible to get Skin Doctor Wet and Wild to work with aftermarket gen grafts on G8F? The literature appears only to address support for DAZ gens, but it seems reasonable to ask about other support or workarounds.
Thank you!
  • Richard HaseltineRichard Haseltine Posts: 111,792
    If they come with scripts or other tools for aplying the base materials to the grafts you could try rerunning those after applying the overlays.
  • RenderPretenderRenderPretender Posts: 1,041
     The wet pruduct and the aftermarket gen both use shells, which seems to be the issue. It'd be good if the PA could offer an assist on this if possible.
    edited May 2022
    Well, you could try applying the texture matching utility to the shell, though I suspect it wouldn't work. It would really be up to the maker of the Anatomical Elements product to address this, though.
    That doesn't work. The product literature should really address this issue, since those who use aftermarket gens are very likely in the overwhelming majority. It's frustrating to discover a product's limiting factors only after buying it, since that's when you gain access to the documentation.
    Readmes are available through the Help centre.
    You could equally say that the makers of the alternative Anatomical Elements should expect that people will use them with products like the Tan Lines or Skin Doctor and make sure they provide guidance for doing so (assuming they do not in fact do so).
    Okay, you can't help me. I get it. Thanks anyway.
