Instances to Objects, Position only
I'm not sure if this is possible, but is there a means of exporting nulls or such for Instances that just has the Pos, Rot, Scale info, in other words NO geometry? Seems like it should be doable.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,486
    https://www.daz3d.com/alienator-pro
    replace with a tiny polgon like a plane?
    as for instances FBX shows them as nulls in some softwares
  • Doc AcmeDoc Acme Posts: 1,153
    The Alienator Pro idea is worth some tests.
    I've tools that I can manipulate, covert nulls or points to instances. Just a matter of getting DAZ to cough up the data.
    If I could get the vector info into nulls, that would be ideal. The info is already there I think, not being generated dynamically, so if I understood DS's instancing methodology better that might be what is needed.  Basically, if you took something like Instances to Objects and had it stop short; leave a null instead of an object.
    Thanks!  I'll take a look later on.
