Straight stairs
Hello,
I'm looking for a straight staircase or a U-shaped staircase to put in a custom house.
For the house I use the parts from the set https://www.daz3d.com/european-style-apartment
Can anybody help me?
  • McGyverMcGyver Posts: 7,101
    edited May 2022
    Wouldn't the height of the ceiling and the length of the run have to be very specific?
    Stairs are a hard thing to mix and match... I've done a lot of architectural models and every time I hope I can reuse a set of stairs from another project, it turns out it's usually just less trouble to make a new one.
    Edit...
    I looked at the set you linked to... are you thinking more like an exterior staircase where something like that might not matter as much?
    Post edited by McGyver on
  • tim3561tim3561 Posts: 27
    Hi,
    Thank you for your response.
    I'm looking for a staircase that would connect two floors in an ordinary house. So nothing for the outside area or a stairwell.
    I also have no problem if I have to trick something. The two floors will be two different sets anyway, so I just have to be careful not to show too much of the stairs in the worst case.
    However, the only staircases I find incredibly ostentatious (for mansions, etc.), are intended for medieval settings, outdoor use, gratings, or are curved.
