Can't cover [breasts] on Gen 8
PreirinPreirin Posts: 6
edited May 2022 in Daz Studio Discussion
I am attempting to use a Gen 8 female to create al elven warrior look, using items such as the JS vest, etc. to give something of a look.  However, even without making the breasts of the character ludicrous, the vest refuses to cover them, allowing them to cut through the material of the vest itself.  Is there a way to fix this?  Auto-fitting and manual fitting don't seem to do it.  Help?
I want a cute character, not an elfish tart...
    edited May 2022
    Do you have something against elfish tarts?
    Edit->Figure->Geometry->Add Smoothing modifier helps some.
    If you select the (autofitted) vest and enable showing hidden parameters, all the morphs that are active on the figure, can be seen and adjusted on the vest and you can for example increase the size of the bewbs to get the vest to cover them
    Post edited by PerttiA on
  • Richard HaseltineRichard Haseltine Posts: 111,362
    If you put the Viewport into Smooth Shaded Drawstyle (cmd/ctrl 7 - cmd/ctrl 9 will go back to Texture Shaded) then you can post a screenshot of the issue.
    That said, the JS Vest seems to fit adequately to Genesis 8 Female base after AutoFit - though there is nasty distortion on the button by her right breast, adn the polygons are very stretched which is going to show in the maps.
    1000 x 1000 - 755K
