Posing Characters and Scene Laggy
Hi Everyone, After almost 2 year wait, I finally got a Evga RTX3090! While the render speeds are ridiculously improved over my 1080TI to my surprise the same scene's that lagged when posing still exist. Even with the 3090. Can you give some suggestions to help get rid of the lag? It's extremely difficult to pose an arm/leg or head when the change occurs two seconds after I make the move. Best Anthony
  • GordigGordig Posts: 10,798
    The viewport doesn't utilize the GPU at all outside of Iray preview, and even then only for the actual rendering. What causes viewport lag is things like mesh subdivision, smoothing modifiers, and the number of morphs loaded.
  • mangiomcmangiomc Posts: 15
    edited May 2022
    I had the same problem using Dforce hair. Try to delete the hair you are using (not hide, delete) and see if it helps.
    Post edited by mangiomc on
