Installing iray
BradCarstenBradCarsten Posts: 856
I've installed Daz 4.8 and when I go into render settings there isn't an option for iray under render engines. I only have 2 for 3Delight and 2 for opengl. I've scoured the forums but haven't been able to figure out how to get iray into Daz. Is there something I need to install first?
    IRay should be part of the DS4.8 install, there is nothing extra to do that I know of.
    I don't have the new build installed yet, but in the Beta version, there is a folder called 'libs' which holds all the IRay stuff.
    Are you sure that you have installed DS4.8, and not 4.7? Help > About DAZ Studio will tell you for sure.
  • mrposermrposer Posts: 1,136
    You may have the 32bit version of DAZ Studio 4.8
  • BradCarstenBradCarsten Posts: 856
    Yes, it's definitely 4.8
    Yes I installed the 32 bit version. Does it only work on 64bit?
  • BeeMKayBeeMKay Posts: 7,019
    Yes, Iray is only in the 64 bit version of DS.
    Well that would explain it then. Thanks everyone.
    edited May 2015
    Sorry bradrg, I had completely forgotten that it only worked in the 32 bit version, and thanks for reminding me Mr Poser.
    Post edited by JimmyC_2009 on
    No problem. I actually do have windows 10 64bit, but I was hoping to test 4.8 out before installing it there and finding that some of my plugins no longer work after the upgrade.
    Most of the plugin problems during the beta were because of the split way the beta was installed...after a reinstall/manual install most plugin problems disappeared. There was no update/upgrade to the scripting or plugin structure, at least in the change logs and per the official announcement thread.
  • Cris PalominoCris Palomino Posts: 12,842
    In the interest of keeping information where people can find it, we're pointing people to this thread which takes you to threads where you can get more information and ask questions.
