I derped up (hiding and unhiding Parameters?)
Okay, so I started trying to manually rig a belt strap.
Trial and error, and things are going...well, they're going.
I made it into a SubD, so now there's the Resolution options in the Parameters section, but in there, I accidentally hid the Mesh Resolution one (IodLevel, I think it was), and now I can't UN-hide it, nor can I find where I'm supposed to be able to unhide it.
Help?
There's a small "listing" symbol in the upper right Corner of the parameter pane. Click on it. It should show you "Show hidden Parameters" somewhere on the list. If you check that, with a bit of luck you'll see it again. :-)
I think you then have to go to the slider#s setting, which controls the hid/unhide.
