Daz3D crashes when defining a long array of integer values
Why Daz crashes when I try to define this array in the Script IDE pane?
Running the simple code below (just the array definition makes my Daz to crash):
Had to upload the code on pastebin, the forum doesnt like me to paste such a long array.
https://pastebin.com/mjHKMKek
This is less than the actual number of vertices in a G3F body. I'm trying to define the array to select some of the vertices.
Post edited by Neverdie Axis on
  • Richard HaseltineRichard Haseltine Posts: 111,862
    The crash report says:
    DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\QtScript4.dll" at 0033:0000000019DFE1BC, QScriptEngine::signalHandlerException()+18380 byte(s)
    so on the face of it it appears to be a Qt issue. Have you tried splitting the array assignment down - assign the first blick of vertices, then add in another blocj and another to build the complete list?
    This seems to work, and builds an array with all the values up to the limit - if you were actually skipping some you would need to add code for those.
    var vertexThatShouldNotBeMorphed = [];
    for ( var i = 0 ; i < 17417 ; i++ ) {
    vertexThatShouldNotBeMorphed = vertexThatShouldNotBeMorphed + [ i ];
  • Yes, just splitted the big array into 3 smaller arrays and now it no longer crashes...
