SOLVED - Another setting problem
HeraHera Posts: 1,962
edited May 2015 in The Commons
Hello!
After re-downloading DAZ I cannot navigate the tree anymore with f.i. pressing P to reach People, L to reach light anymore. All those actions instead make the camera skip around. So I have to scroll like it was the 90ies. Or is there a way to make the keyboard operating the files tree again (like in windows explorer and most other tree structure programs)?
Post edited by Hera on
    You may have an icon in the Toolbar for doing it, but the quick way is to use Shift+K.
    I'm not stalking you , honestly, just having a last look in before bedtime. :)
  • HeraHera Posts: 1,962
    edited May 2015
    And please, where is the toolbar, since Shift + K is not working anymore since I downloaded 4.8 :-O
  • Richard HaseltineRichard Haseltine Posts: 110,460
    Try reloading your layout - it may be that something was reset by the update, though shift-k should be the default (it's certainly working as a toggle here).
  • BeeMKayBeeMKay Posts: 7,019
    Go to "Tools". Select Scene Navigator.
    Go to Windos --> Panes --> Tool Settings.
    It will show you the Scene Navigator tool.
    Now. click the icon in the upper right corner of the the Tool Settings pane (marked in the image). It will show you a list.
    In the list, the top item reads Keyboard Navigation. It has a small icon in front of it which should be yellowish, or otherwise marking it as "activated.
    Click on the small icon. The listing will close.
    If you click on the upper right corner again to show the list, all options below the "Kyboard Navigation" should now be closed.
    551 x 563 - 28K
    edited May 2015
    YES - that did it! Thanks lee_lhs , I'd never found that mystery path on my own. Now I can finally browse again :) :)
