Thanks AM for the Stoat/Ermine/Weasel...so cute
AllenArtAllenArt Posts: 7,175
It's really adorable :D
  • Doc AcmeDoc Acme Posts: 1,153
    I really really want him, but unfortunately I can't use dForce hair as I export.  I hope AM considers an LAMH preset, particularly since the hair so short.
    Then again maybe this is a good figure to try & make my own...
  • GordigGordig Posts: 10,792
    What do you export to? I know C4D can import dForce hair as splines, and I imagine other programs can as well.
    And yes, this is super cute, and makes it apparent that I didn't know the difference between a weasel and a badger.
  • JOdelJOdel Posts: 6,322
    Yeah, I finally caved, but without 3DL materials, i don't know that i'll ever actually use it. Maybe without fur at a distance after converting the matts.
  • alexhcowleyalexhcowley Posts: 2,409
    edited May 2022
    Incredibly cute and a must buy for me. It's a great pity Chohole is no longer with us, she would have loved this.
    Cheers,
    Alex.
    P.S. How about a Red Panda next?
    Post edited by alexhcowley on
  • FSMCDesignsFSMCDesigns Posts: 12,855
    I used to think Stoats/weasels were all cute and cuddly till i saw this video of them taking down rabbits 4 times their size. Vicious little critters
    Out of Daz using FBX & into Lightwave.  I can then transfer weight maps to the fur, making the posable with fur, but no morphs. At least yet.
    dForce hair exports as polys. They're almost splines in that they are all separate, & are single points with beginning & end points. But they get closed somewhere in the process.
    I'll have to check into that with CD4.
  • Oso3DOso3D Posts: 15,115
    Mention of 3dl got me thinking.
    Here's a render in 3dl (used iray -> 3dl converter for the skin, added reflection to the cornea, converted fur to ubersurface. Yes, it's one flat color, but it works)
    2000 x 1000 - 773K
    The trick is to turn line tesselation to 0 so that it's not exporting any geometry, and export as OBJ. You could give that a try with Lightwave, but I don't know if that has any sort of hair system.
    Quote
    That's in C4D or Daz?
    If in Daz, where is that paramater? I set mesh resolutiom to Base no the mesh but this sounds a different param.
    Line tesselation is in the general parameters section of the actual hair object, not the haircap. You'll see viewport and render line tesselation parameters, and I zeroed them both, but it's possible that zeroing only one of them would work.
  • xyer0xyer0 Posts: 6,503
    I guess the cat must be reeeeeally difficult to make.
    Most in the weasel family are pretty vicious. LOL.
    yes
    At least we have Zeus ;)
    Asian short-clawed otters are also well worth avoiding. They have very powerful jaws in proportion to their size. Petting one is extremely illadvised, you could very well lose a finger!
    Cheers,
    Alex.
    Thank you Oso3D for the 3DL image. That sounds highly doable.
  • So who's going to be first to make a ferret texture for it? LOL
  • butterflyfishbutterflyfish Posts: 1,791
    I second the interest in a ferret texture.
  • edited May 2022
    No one's added a link to it? https://www.daz3d.com/weasel-by-am - there, next time I want to find this discussion it'll be easier. :)
    I'm about to start a render of my wip villain, Jill, who uses ferrets for crime. (I've designed her outfit but I still need to decide which bodysuit I'm actually going to use before I start trying to make textures... And if I want to put tiny little ferret ears on her helmet or if that's too much)
    She's vain as heck, manipulative, greedy, and arrogant, but she ADORES her ferrets.
    Post edited by lydean_works_29f84bcdcf on
  • Here's Jill and a white ferret
  • LeatherGryphonLeatherGryphon Posts: 12,449
    Stoat/Ermine/Weasel  Don't forget Minks and Ferrets.
    You're welcome!
  • edited May 2022
    I really appreciate how well it's rigged. It's very easy to use. I'm going to be working on ferret textures (probably a couple of color varieties) in a while and I also appreciate that it doesn't look like that'll be too complicated.
