Looking for a clean newish looking Albert Mansion
Hi all as it says above I am looking for a clean newish looking Albert Mansion. I really like Albert Mansion but need an undamaged looking building anyone know of one or one of the same style. Thanks again
  • MelanieLMelanieL Posts: 7,892
    Someone posted this in the forum when it was first released - clean enough for you?
  • lou_harperlou_harper Posts: 1,163
    I wouldn't mind a few more add-ons for the Albert Mansion in general. For example a green, spring time environment instead of all the dry weeds.
  • myotherworldmyotherworld Posts: 665
    Thanks that was just the information I needed. OK so no there is no clean model available but it looks to be doable. Thank you
    You saw that the second attached file was the .duf file to install in your library to load it in the pictured clean state?
  • kyoto kidkyoto kid Posts: 42,499
    ...one issue is the columns as the pattern is the same on all 4.  They also share the same MAT zone as I understand so if you rotate the shader on one in the sirfaces tab, the details on the remaining three would rotate teh same degree as well. The only way around that is to use the Geometry Editor to make each one it's own surface.
  • xyer0xyer0 Posts: 6,522
    That may be a fairly straightforward, though perhaps time-consuming, exercise.
  • Matt_BrownMatt_Brown Posts: 178
    I might be possible to rotate each column individually. That way they would appear different from any one camera angle.
  • StoicStoic Posts: 157
    In this thread forum member jcade has provided a columns offset alt UVs
    https://www.daz3d.com/forums/discussion/comment/6071772/#Comment_6071772
  • FSMCDesignsFSMCDesigns Posts: 12,858
    Depends on the modeling. There is a selection when selecting polys called "select connected" which selects all the polys of a single object in one click
