List of Autofit / Transfer Utility Clones
ScavengerScavenger Posts: 2,677
edited May 2015 in The Commons
What "clones" are available out there to expand what Autofit and Transfer Utility can work on?
Here's what I know of:
AUTO FIT TO GENESIS 2
Genesis -> G2F/G2M
Built in
V4 -> G2F
http://www.daz3d.com/victoria-4-for-genesis-2-female
M4 -> G2M
http://www.daz3d.com/michael-4-for-genesis-2-male
AUTO FIT TO GENESIS
G2F -> Genesis
http://www.daz3d.com/genesis-2-female-clone-for-genesis
G2M -> Genesis
http://www.daz3d.com/genesis-2-male-clone-for-genesis
Gen3 -> Genesis
http://www.daz3d.com/gen-3-iconic-shapes-for-genesis
David 3 ->Genesis
http://www.daz3d.com/david-3-for-genesis
Or there others? In Store? Freebies? Generation 3? Dawn?
Post edited by Scavenger on
  • ScavengerScavenger Posts: 2,677
    And that is Gen3 -> Genesis but not genesis 2, right?
  • HavosHavos Posts: 5,692
    You can transfer all the Genesis Gen 3 shapes over to Genesis 2, so they are available on Genesis 1 or 2.
  • LeanaLeana Posts: 13,476
    Yes, this is Gen3 -> Genesis, but you might be able to transfer the clones to Genesis 2 with GenX2.
    David 3 for Genesis has D3 -> Genesis clone too.
    With gen x2 and the genesis 2 add on you can transfer all the shapes with a few clicks each. You can also make clones for them for wearing gen 3 clothing on Genesis 2. This is a bit more fiddily, but there are tutorials around how to do it.
    I believe you can also transfer shapes using the transfer utility, but I have never done it.
  • Richard HaseltineRichard Haseltine Posts: 111,216
    I don't understand about "Transfer the clones with Gen x2" That transfers morphs and shapes.
    I'm not interested in the shapes or morphs..just the things that make Autofit and Transfer utility work.
    A clone is nothing more than a shape saved with some particular parameters, that autofit will use as a base to adjust the clothes' shape to the target figure. Then the resulting "objects" are rigged aitomatically using the projection templates.
    Leana is correct in that you need the shape to create the auto fit clone needed for fitting clothing. Currently there is no product you can buy that will give you the Gen 3 clones where all you need to do is press the install button. Instead you have to copy the shapes over from Genesis to G2M/G2F and then use these to create the clones. It is not rocket science, but it is not as trivial as pressing the install button either.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,423
    Any morph that can be loaded onto Genesis, G2M & F can be made a clone.
    Using Crossdresser and genX I even made a Krystal Starfox one which makes me suspect if you had a license for all the Crossdresser supported figures they could all be cloned.
    That is interesting, I am quite keen to have a morph (and clone) for V2 and M2.
    edited May 2015
    Same here but V3 works quite well for V2 except for shoes in the meantime.
    I do not have the Crossdresser licenses to test my theory.
    What I do do is use Crossdresser to convert to V4 who I do have one for then fit to G,G2M&F.
    And once you make these, somehow Autofit/ Transfer Utility will be able to use them?
    edited May 2015
    see Katey's thread on making clones
    http://www.daz3d.com/forums/discussion/24093/
    Yes of course. When you fit an item not native to G2F/G2M then the autofit popup box comes up and the clones I have created appear in the drop down list when you are selecting the source model for the clothing.
