shrinking fists (fingers look wierd)
Anyone have this problem? A number of models, if I apply morphs to them, will do this with the fingers if I have them make a fist:
927 x 666 - 303K
  • SquishySquishy Posts: 727
    "a number of models" which ones exactly, does it happen with the dev load of whatever generation you're looking at, how are you applying morphs exactly, is it happening with alm morphs, if not which ones etc.
  • Richard HaseltineRichard Haseltine Posts: 111,491
    Your own morphs or morphs from a product? It looks as if the rigging needs adjusting to the new shape, if currently the joint centres are out of place relative to the current shape then the bends will be wrong.
  • TorkudaTorkuda Posts: 148
    Well this particular model is Genesis Male 8 with the lincoln child morph, but I've seen similar issues with other model morphs on Genesis 8 female as well.
    How do I fix joint centers?
    edited May 2022
    How does one adjust rigging?
    (Solution found. Models can often be fixed with this issue by simply going- edit:figure:rigging:adjust rigging to shape Easy solution.)
    Post edited by Torkuda on
    good to know yes
    A store character or morph should already be doing the adjustments. Make sure you are using the current version (if you installed  manually redownload from your account and reinstall, if you used one of the isntallers let them go online to check for updates) and if the issue persists please open a Technical Support ticket to report it https://www.daz3d.com/help
