are G2m and G2f the same mesh?
MistaraMistara Posts: 38,675
was just remembering was able to import m4's uvs to v4.
was wondering if could add g2m's m4 uvs to g2f
- there's m4 creature skin i'd like to use on g2f
thanks
  • Richard HaseltineRichard Haseltine Posts: 111,359
    Yes, the mesh is the same. So yes, you can apply the G2M UVs to G2F and vice-versa.
  • RedzRedz Posts: 1,459
    Oh I was wondering exactly this. Could someone please provide instructions on how to go about transferring the uv set? Thanks
  • almahiedraalmahiedra Posts: 1,374
    Use UV Setter Gen2 slosh freebie in sharecg, I believe.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,505
    Copy over the data files
  • HavosHavos Posts: 5,703
    After copying over the relevant file from the "UV Sets" folder in the data area, I believe you also need to edit the file to replace Female with Male in the id, though I am not 100% certain if this is needed.
  • SpyroRueSpyroRue Posts: 5,020
    edited May 2015
    Its quite simple just to copy over the UV folders from the respective G2 gender to the other. No need to edit any .dsf Just copy and paste.
    EG. Copy "Victoria 6" from "My DAZ3D Library>data>DAZ 3D>Genesis 2>Female>UV Sets>Daz 3D" and paste it in "My DAZ3D Library>data>DAZ 3D>Genesis 2>Male>UV Sets>Daz 3D"
    You can also just apply a characters mats to the opposite gender too, which will make the UV it uses work on the opposite gender figure within that scene. But I copy them all to both genders of Genesis 2. Much more useful having them permanently on both figures.
    Post edited by SpyroRue on
    Thanks guys, that worked a treat. Appreciate all of your helpful comments :)
